Installing a sounds customz anp & speakers and the instructions arent the best, anyone know of better pics or a video to help me figure it out? Im not a big electronics guy and just want to make sure I do it right, any help appreciated!!
Essentially all amps and speakers are installed the same. Power, Ground and Remote turn on. Then pos and neg to each speaker. If Soundz ships their kits with custom wiring connectors I would call them for support since their kits are quite pricey ---- I'd start there. Not many "regulars" on here running their stuff. I'd go straight to the source man.
Spazz you have that XDI600.4 in your bag or fairing on the RGS?
in the fairing. under the HU... I have a new inner support bracket I purchased from Soundz..... Drilled and tapped 10x32 mounting holes in new bracket, mounted amp and HU... re-installed in RGS... not a hard job
OEM support on left... new support on right with XDI mounted under HU
