Amp cutting out
Old Apr 4, 2016 | 09:07 AM
rattracer's Avatar
rattracer
Default Amp cutting out
Moved my Rockford Fosgate PBR300X2 from my old bike to my new one. Music is cutting out after riding about 20 minutes. Seems like amp may be overheating - it's worse when the volume is cranked up. I turned the gain down on the amp, which helped, but it still cuts out when I turn up the volume. How do I diagnose this issue?
Old Apr 4, 2016 | 09:13 AM
haze324's Avatar
haze324
where are you grounded?
How's your battery?
Old Apr 4, 2016 | 09:17 AM
RatPwrd72's Avatar
RatPwrd72
What Haze said... 2 ohm speakers or 4?
Old Apr 4, 2016 | 09:32 AM
haze324's Avatar
haze324
Also what bike and where are your gains set?
Old Apr 4, 2016 | 12:35 PM
Gannicus's Avatar
Gannicus
How's your battery?
Yep. . Check the battery and ground.
Old Apr 5, 2016 | 09:01 AM
rattracer's Avatar
rattracer
Same as the old bike, 10 gauge hot wire direct to battery with inline fuse, grounded to frame under front tank mounting bolt. I'll double check those connections tonight, pretty sure they're good, but never hurts to check. Bike is a '16 Street Glide, with 2 Kappa speakers in the fairing (2 ohm). Thanks for all the replies.
Old Apr 5, 2016 | 04:58 PM
wils5150's Avatar
wils5150
bring that ground back to the battery. I am pretty sure they have a bulletin on the rockford website saying so.
Old Apr 5, 2016 | 05:07 PM
SBates08's Avatar
SBates08
I installed one of these for a guy over the weekend. Grounded at battery and had no issues with it cutting out. The amp did seem to get extremely hot though. I contributed it to the crappy J&M speakers he was using LOL!!!!
Old Apr 5, 2016 | 11:07 PM
Tailwind's Avatar
Tailwind
What make, model, year of sled?
T
Old Apr 6, 2016 | 12:00 AM
matt76cmich's Avatar
matt76cmich
T
2016 Street Glide
