which amp?
i used 8 ga pwr and grnd to battery, added an aditional ground from hu chassis(14 ga), twisted all 3 together, wrapped them in copper foil tape and maintained perfect fm teception on my aquatic av/cerwin vega B54 combo. was it all the prep work or just luck? no clue but i only wanted to do it once
Thanks for all of the input and glad I mentioned the 4ga wire. I just wish that I would have mentioned it prior to ordering the 4ga wire and connectors. Other than being harder to work with would the 4ga have a negative effect?
The manual in that section is still referring to automotive installation where wire length needs larger gauge due to the longer runs. The 5-6 feet ran on a bike is plenty sufficient to 50 amp draw range in 8g for power and ground. Also twisting will have zero benefit on FM reception. Placebo effect. I have the cheapest crappiest antenna for FM known to man and still pick up few stations running 2 amps and phase 7 headlamp. Run the power on the left side to battery and ground to the right. The arc is well emi shielded and you should have majority of your stations still.
When I put the 4180 in my Limited Low I all but lost AM & FM. Tried the ferrite beads, etc, no help. As a test I hooked the power leads to a lab type 12v power supply.... AM & FM back. The interference was coming from the bike. Twisting the power leads is an old trick learned in my CB radio days... CB (for the most part) is AM and suffers from the same type of interference. I regained probably 75% of my signals.
Going from maybe 10% to 75% is not a placebo effect.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
zero negative besides size. The Arc is designed for 8g input so twist your wire well.
Class D amplifiers emit emi(radiation) internally in the power rail switching on/off at very high speeds. This creates the emi emitted. Never heard of BT having any FM issues as it has been designed with a good shielded power supply. The input power and ground have nothing to do with the emi and will not increase nor reduce it since all the radiation is coming off the amps circuitry. So Yes twisting wire in this specific case is pointless. To say it changed could have been a poor connection somewhere to antenna location, to who knows. Either case the supplied power and ground connections are irrelevant to the amplifier internal circuit emitted any less emi than the engineer has designed.
which amp?
Originally Posted by slyedog
No unless you wrapped the amp in it then it
ok. ill buy that. does amp location contribute to radio interferance? above the hu as opposed to a tourpak or saddlebag?
The 600 will be fine on too of radio. Most times antenna location (inside fairing style) is the factor of good or bad FM reception. Also location. For example in rural areas with good distance from the closest station you will have a loss in some instances in stations you previously picked up, but again with antenna location and since the emitted emi has no real rhyme or reason you may see minimal loss at most with the Arc 600.4 .
Class D amplifiers emit emi(radiation) internally in the power rail switching on/off at very high speeds. This creates the emi emitted. Never heard of BT having any FM issues as it has been designed with a good shielded power supply. The input power and ground have nothing to do with the emi and will not increase nor reduce it since all the radiation is coming off the amps circuitry. So Yes twisting wire in this specific case is pointless. To say it changed could have been a poor connection somewhere to antenna location, to who knows. Either case the supplied power and ground connections are irrelevant to the amplifier internal circuit emitted any less EMI than the engineer has designed.
I'm sorry, but in my case it was the cure. I tried running the wires along different routes, grounding at different points, double checking antenna connections, etc. nothing helped until I twisted the power leads.
Another hint that led me to the power leads...
I would have the system powered up and tuned to what should be a strong station.... no reception. Unplug the power lead from the amp, and for just a second before the amp powered down the signal would come in strong.
Twisting power leads in radio communications systems is well documented.
which amp?
Looking at my 600.4 amp power and ground hookups and i don't think you could get a #4 in there...even with some KY.
I bought the Arc MC amp hookup kit for the 600.4 and it came with #8 power and ground
I don't have the amp in my hands yet, I ordered it from LL a week ago last Friday so I expect it any day. I was going by the Arc 600.4 instructions which state 4ga minimum in one place and 8ga minimum in another. I ordered 8ga after reading Slye and others responses so I should be good. I thought the twisted power and ground wire question was an interesting one but apparently it has no basis.
