Power and ground wiring for amp
Old Jul 4, 2016 | 05:53 PM
Springerfan's Avatar
Springerfan
Default Power and ground wiring for amp
I have received a lot of help on this forum for putting together my upgrades and I have placed orders for new quality speaker, power and ground wiring. I am using 16ga twisted pair speaker wires and 4ga power and ground wire with the correct connectors. I read somewhere on this forum a while back that twisting the power and ground wires together to make them twisted pair would help with cutting FM interference from the class d amp. What are your thoughts, is it worthwhile,have a downside or a total waste of time?
Old Jul 4, 2016 | 06:45 PM
yooperhog's Avatar
yooperhog
4 ga is some awful stiff wire. good 8 ga is plenty. will the 4 ga even fit in amp lugs?
Old Jul 4, 2016 | 09:55 PM
Springerfan
The instructions for the amp said to use 4ga so I would imagine it will.
" A 4 gauge or larger wire should be used for power and ground connections."
Old Jul 4, 2016 | 10:06 PM
ROCKOUT Rocker Products
Sponsor
That was me that used the twisted pair power & ground wires, I ran them that way all the way to the battery from the amp (BT4180)
It was the only thing that helped my FM reception.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 4, 2016 | 10:26 PM
haze324's Avatar
haze324
a bike does not produce enough juice to warrant a 4awg wire.
Old Jul 4, 2016 | 10:35 PM
Springerfan
It's an Arc moto 600.4 which I thought was designed for motorcycles and I copied that directly from the instructions for the amp. I thought it was abit large also and I have used 8ga on other amps but I assumed that they knew what they were talking about when they wrote the manual. What do you use haze?
Old Jul 4, 2016 | 11:26 PM
Tailwind's Avatar
Tailwind
I think if u go down into the manual a bit in the "Installation" specific section, there is text that states 8 awg minimum in parens so at least u know that 8 will be acceptable. Pretty damn interesting to see this conflicting info but I would run with the 8 since it is stated as an acceptable minimum gauge.
T.
Old Jul 5, 2016 | 12:10 AM
slyedog's Avatar
slyedog
T.
The manual in that section is still referring to automotive installation where wire length needs larger gauge due to the longer runs. The 5-6 feet ran on a bike is plenty sufficient to 50 amp draw range in 8g for power and ground. Also twisting will have zero benefit on FM reception. Placebo effect. I have the cheapest crappiest antenna for FM known to man and still pick up few stations running 2 amps and phase 7 headlamp. Run the power on the left side to battery and ground to the right. The arc is well emi shielded and you should have majority of your stations still.
Old Jul 5, 2016 | 04:35 AM
yooperhog's Avatar
yooperhog
which amp?
i used 8 ga pwr and grnd to battery, added an aditional ground from hu chassis(14 ga), twisted all 3 together, wrapped them in copper foil tape and maintained perfect fm teception on my aquatic av/cerwin vega B54 combo. was it all the prep work or just luck? no clue but i only wanted to do it once
Old Jul 5, 2016 | 05:41 AM
haze324's Avatar
haze324
What he said! +1
