EG Police simple setup
Old Jul 27, 2016 | 05:39 PM
yooperhog's Avatar
yooperhog
Originally Posted by Gannicus
He would be using his phone.
ahhh. plugged in via USB. Now, will that also charge at the same time?
Old Jul 27, 2016 | 07:17 PM
Keith4001r's Avatar
Keith4001r
This is moving faster than my comprehension (almost). Glad there are folks like y'all who are in the know and willing to share the knowledge. Many thanks.
Old Jul 28, 2016 | 09:27 AM
Gannicus's Avatar
Gannicus
Yes Sir! It's the perfect set up. Phone charging and streaming quality music.
Power and Ground to the battery. Remote to the orange/white headlight harness. The RCA's are on the harness.
My man asked for Simple. This set up is about as simple as it gets!
Old Jul 28, 2016 | 10:14 AM
Keith4001r's Avatar
Keith4001r
I have a question about the Polk MM651s- 100 w continuous at 2.7 ohms? How would I achieve that load? How would that equate to a 4 ohm output? I don't understand this electrical stuff.
What would the next step up in speakers be? Thanks much for all the advice.
Old Jul 28, 2016 | 11:34 AM
yooperhog's Avatar
yooperhog
you need an amp thats 2 ohm stable,speakers can be higher in impedence (ohms) than the amp, but not the other way around.
for example a 2 ohm amp will run 4 ohm speakers but a 4 ohm amp will not run 2 ohm speakers
lots of very respectable amps mentioned in these forums are 2 ohm stable, so when choosing one, make sure u check the spec sheet or simply ask. any amp your concidering has probly been used by someone here
Old Jul 28, 2016 | 11:49 AM
Gannicus's Avatar
Gannicus
Those speakers are plenty capable of getting you the sound you are looking for! No need to stress on the resistance of the speakers. I've already done that for you. As hog said as long as the AMP is 2 and 4 ohm compatible you can run two or four ohm speakers. If you want a step up 4 ohm speaker you're getting into the Hertz and focal stuff.
Old Jul 28, 2016 | 02:43 PM
Keith4001r's Avatar
Keith4001r
Well, for now I have an iPod and some earbuds. I think I'm on a mission to learn about amps, speakers, impedance, loads...
Teacher, may I go home now? My brain is full. Again, thank you all very much.
Old Jul 28, 2016 | 04:11 PM
yooperhog's Avatar
yooperhog
lol. just keep browzing the threads here. it will make sense soon enuf. i was in your shoes 6 months ago. worse actually cuz my first speaker purchase was J&M. they are currently collecting dust right along side of a pair of blown hogtune speaks. expensive lesson learned to say the least
Old Jul 28, 2016 | 08:47 PM
Gannicus's Avatar
Gannicus
LOL!!! What he said!
redliner996
Audio Systems
Jun 7, 2017 03:00 PM
JP374
Audio Systems
45
Apr 25, 2016 08:43 AM
Softy 103
Audio Systems
31
Oct 19, 2014 09:08 AM
bking
May 10, 2012 09:29 AM
pauletich
Apr 26, 2011 12:03 PM
