BT Line Levelers
Old Sep 22, 2016 | 10:01 PM
Gooey2's Avatar
Gooey2
Default BT Line Levelers
Anyone had a line leveler crap out? If so what were the symptoms ?
Old Sep 22, 2016 | 10:48 PM
Bertk's Avatar
Bertk
I have seen where they have failed on the forum. It turned out to be one of the output wires coming from the LL. While connected and playing a song wiggle the output wires to see if it makes a difference. As for symptoms, it could be poor sound to no sound at all.
What symptoms are you experiencing?
Have you tried eliminating the LL and connecting a speaker directly to rule out other possible causes?
Old Sep 23, 2016 | 05:17 AM
Gooey2's Avatar
Gooey2
Well that pretty much describes it. I've searched all over loose connection,only right speaker. Well I'm in there again. Im almost ready for a single din radio I tell you.. Thanks for the effort, get ahold of biketonics.
Old Sep 23, 2016 | 06:51 AM
Bertk's Avatar
Bertk
Yes, give BT a call. They may just ship you one out today.
Old Sep 24, 2016 | 05:43 AM
Gooey2's Avatar
Gooey2
Well off with the lid again.......back to an earlier thread. After some more fiddling around, fired up the stereo and I swear a difference. I zip tied around the RCA connectors both around all 4 on the amp and at the LL's. I guess new rca's I may still zip tie them.
Old Sep 24, 2016 | 01:09 PM
Bertk's Avatar
Bertk
I have found the BT RCA's to fit the amp just fine. When it comes to the LL's they do not seat all the way. Between the four brand RCA's I have tested the Krystal Kables fit the LL's the best. If the cables are secured properly there should be no tension put on them when moving the bars all the way to the left and right stop.
Old Sep 24, 2016 | 09:41 PM
Sean Kirkpatrick's Avatar
Sean Kirkpatrick
I had one that was doa. The input wires on one channel were faulty and caused crackling while they shook. BT replaced it in days
Old Sep 25, 2016 | 05:45 AM
Gooey2's Avatar
Gooey2
Thanks BERTK those cables look like the s....t they are on their way!
legoiii
Audio Systems
17
Dec 22, 2016 12:09 PM
Dew Me
Audio Systems
11
Apr 27, 2013 08:29 PM
0ldhippie
Audio Systems
Apr 8, 2013 02:19 PM
dabrogger
Feb 23, 2010 07:30 PM
Dino3981
Apr 25, 2008 01:19 PM
