I'm installing the Biketronics amp and speakers in my 16 Streetglide. I'm now trying to install the speaker brackets and the instructions are not helping. It seems that the 2 stock small screws that are being reused to attach the bracket on the top side are not long enough to bite. Am I doing something wrong or should I just get longer screws?
Anything else that I should know while I'm doing this?
Help much appreciated.
Those top screws should fit perfect but if u have time on your side run to the hardware store and get some hex head bolts to replace the stock ones and if u want them just a touch longer it will not hurt a thing.
Replace them with hex bolts, much easier to work with. I believe I use 1" long with washers and lock washers. Take a quick measurement just to be sure.
