Yea I wish I would have went the VO's way on this bike but I'm working with what I've got.
Haze's project bike is my 2017 CVO. Probably going to stuff that full of them.
That looks to be a great amp just not sure it's worth the coin to swap the arc 600.4 for it or just work with the arc I've already got installed.
I need another hobby...
Both amps are a constant power design, so they deliver same power 2 or 4 ohms. The upside to the arc is although it has less warmth per say it has the raw power and sound for the high speeds and also you will have a little headroom with the Arc vs no headroom with the Rockford. Use the eq on that dsp and it will really come alive.
