Tuning the Biketronics system
Old Nov 3, 2016 | 04:52 AM
billablehours's Avatar
billablehours
FWIW I found that polyfil around the 7.1s helped fullness.
Old Nov 3, 2016 | 09:23 AM
Bertk's Avatar
Bertk
Originally Posted by onedae
Talked with Mike at Biketronics and he suggested moving the filter dials counterclockwise in VERY SMALL increments, checking the sound as I go. I ended up moving the default settings maybe 1/16 to 1/8 of an inch and the sound is much fuller with a reasonable amount of bass. Thanks Mike for excellent customer service. So far only garage tested but I'll get out tomorrow and do a road test.
So far all good.
Moving those dials that much is an enormous change in voltage and effect on gain settings as BB pointed out. Go into audio setting and do a speaker test. I bet both tones sound very different.
Old Nov 3, 2016 | 12:29 PM
onedae's Avatar
onedae
......"Moving those dials that much is an enormous change in voltage and effect on gain settings as BB pointed out. Go into audio setting and do a speaker test. I bet both tones sound very different."...........
I'm not sure what you mean by doing a speaker test?
Old Nov 3, 2016 | 03:10 PM
Bertk's Avatar
Bertk
Hold the Mute button and turn ignition to Acc.
Tap Accept and release the Mute.
Tap on Audio - Speaker Test.
With my LL balanced left to right with a DMM the right speaker is louder. There was a time when they sounded the same.
MasterGunz1775
Apr 6, 2017 07:26 AM
yank721
Audio Systems
11
May 22, 2016 08:03 PM
Choopy
Audio Systems
Apr 7, 2014 12:56 PM
dhellyer08
Audio Systems
16
Oct 26, 2013 11:41 PM
yzergod
Audio Systems
May 17, 2013 11:46 PM
