Here you go. Use the first one "1000Hz 0dB.mp3" unless you are tuning subs. They are 2 minutes long and from SMD. What HU are you using?
OK, I need some clarification regarding all these test tones.
Most of these test tones found online are labeled @0db, however when you analyze them with MP3Gain they are in the 100s.
Could someone clarify this for me?
Thanks in advance.
Thanks in advance.
This is why most music is downloaded at around a 98 db level from most good online sources, such as Amazon. If you drop to level's that mp3 gain doesn't show clipping, you lose near 10db of volume , which is a lot. So I suggest to always set the tone to around 5db above your recording levels. So if you drop all you music to 93, then run a 98 db test tone. A typical -5 db test tone is 98 db. Keep in mind as well the lower the test tone level, the more gain you add, potentially adding noise in the system.
