Accessory or Ignition?
Old Nov 29, 2016 | 05:49 PM
No U Glider's Avatar
No U Glider
Default Accessory or Ignition?
Do most folks running aftermarket amps run the amp turn on lead to ignition or accessory power? I'm going to be running an Arc Moto 600.4 - given the inline fuse is 60 amp and the bike's main fuse is only 50 amp, I'm guessing the amp will have quite a current draw. In the past I've used my bike's stereo to listen to music while working in the garage. Wondering if that is going to become a battery killer ??? A buddy has his turn on wired to the ignition and suggests no prolonged listening unless the bike is running..
Old Nov 29, 2016 | 05:55 PM
Tailwind's Avatar
Tailwind
Accessory wire used for the invisible antenna. If not, use the purple wire for the cig lighter.
Without question u need to go to Walmart and get urself a workshop / garage boom box man. Nothing good will come from using ur sled as a garage boom box. It's just not intended for such use.
T.
Old Nov 29, 2016 | 06:46 PM
Gannicus's Avatar
Gannicus
Ha! You got about 40 minutes Tops!! If you have heavy bass notes 25-30
Old Nov 29, 2016 | 06:50 PM
1BRAVO9's Avatar
1BRAVO9
T.
I must agree.
Old Nov 30, 2016 | 12:30 AM
No U Glider
That Wally Boom Box won't sound as good. Damn!
Old Nov 30, 2016 | 07:13 AM
black01's Avatar
black01
My moto 600 came with a orange remote wire with a plug on it to pug into a factory acc connector.
Old Nov 30, 2016 | 08:29 AM
Bunker's Avatar
Bunker
if you don't want to cut, for $17 you can get one of these: http://www.vtwinaudio.com/store/prod...ire-connector/
Old Nov 30, 2016 | 09:24 AM
TomboAT65's Avatar
TomboAT65
Definitely suggest one of these! Makes the install much easier and cleaner with no cutting or guessing.
hook425
Audio Systems
Jul 31, 2015 07:59 AM
HD_Doobie
Audio Systems
Apr 3, 2015 12:13 PM
TOUCHNGO
Oct 20, 2013 11:44 AM
dontdropit
May 17, 2009 11:00 AM
ranger32@comcast.net
May 22, 2006 09:40 PM
