adding lower speaker pod help with upgrade
Would like to keep speaker - amp updates to less than 2K total for this project.
Currently running a Sony 310, 2 PBR 300x2's in the faring, titan 7.1 in the faring, and pioneer TS6900's in the bag lids.
Have a set of lower farings with 6.5" speaker pods that I want to add but need to figure out the speaker and amp needs.
Know I'll probably need to make some amp changes and can do that just need some guidance. Current setup is good in the garage and parking lot and no issues hearing it going down the road with good sq but want more.
I do also have a set of titan II 6.5's laying around that I could use in the lowers but not by any means has to be a part of the plan.
Do I buy a 4 channel amp for the front end and then move 1 of the pbr's to the bag for the pioneers or ???????? And if so what amp and what speakers. Nothing in the current set up that couldn't be changed - upgraded.
So what would the Audio guru's recommend? Thanks in advance
If you like the sound of the Biketronics speakers. Run the Titan II's in the lowers in parallel with the 7.1's in the fairing on channel's 1 an 2.
Run the Pioneer Pro's on channel's 3 and 4.
The PBR amp's do not push enough power at 4 ohms for the Biketronics speakers to sound like they should.You will notice a HUGE difference with the soundstream amps.
You can do some damage with you are after. I would ditch those amps ASAP you will get much better sound from other amps, but you will likely lose some FM reception with other amps. I'd add a good 4 channel in the fairing - Arc Moto 600.4, Diamond 800.4 and then add a smaller 2 channel. Some amps will fit on the hogtunes second amp bracket if you wanted to keep them both in the fairing. You could use the second amp bridged to a good set of fairing speakers like the DD AW6.5 components, maybe even had some horns in your fairing. Then use the other amp 4 channel amp for lowers and lids. If you have the BT6.5's I would go ahead and use them in the lowers. They'll plenty loud and you can get good bass from quality fairing speakers and those 6X9's.
Would like to keep the amp's in the faring if possible so what's the difference between the soundstream, diamond, and arc. I know this is a subjective question but which is better and/or why is one better than the other.
Unless something wonderful crosses my ears I might just stick with the biketronics speakers.
That said. I'm in agreement with my friend Haze on the type of speaker and the amount of power needed to power those speakers. All the rest of your speakers on the bike are basically "filler" speakers from the lowers, rear pods and saddle bags. So it stands to reason you want high quality speakers in the fairing with plenty of power. Now what I'm about to say goes against conventional wisdom but IMO those fairing speakers need to be mated with one powerful amp!! For example: Could you imagine what those Moto's would sound like in the fairing bridged to a JL MX500/4 @ 250 watts? Not saying that the Moto's are the best fairing speakers out there. But if you are going to run em in the fairing. That's what it takes to make em sing!!
So yeah. Your Moto's are a little underpowered with the SS amp. But we use that amp out of convenience because it's a budget 4 channel with good power. Getting back to my point. Fairing speakers need to be High sensitivity speakers 90db and above with a RMS rating of 80-100 RMS with a clean amp pushing at least 200 watts to the speakers. Again, preferably components or Mid bass drivers with horns. That would be optimal in my opinion based on months and months of research with countless set ups. Now. Can you get by with less? Sure you can! And it will sound damn good! But for guys looking to go next level. That would be my recommendation.
like Alpine Pdx 150x4 .2 ohms 4 speakers front and 4 ohms 2 6/9 in the back , it will be cleaner and louder. i was running this setup since 2006 . and installed 6 system like this for some of my friends . but a newer version of alpine pdx . you can even run same amp running 8 4 ohms speakers . 4 6.5 front and 4 6/9's in the back. Their is some amps that can do the same . but for a good price range alpine PDX 150x 4 is on top of it.
