Hi Guys,
I am installing an Arc Moto 600.4 amp into my 2017 Road Glide Ultra and could use so advice on the initial settings. The front speakers are AD Design CX62 (for now) and the rears are Alpine SPR-60. I am using the BT line levelers. Will the auto sense work with the line levelers or should I connect the remote on wire to the cigarette lighter lead? The bass, freq, and gain are set to the default when I got the amp. High is set to full, and it's set to 4 channel. Attached is a picture. I'd like to get it right, or close to right the first time since it's mounted under the radio and there is a cover over these settings.
Thanks.
I would hook up a remote wire. My moto 600 came with a remote wire that plugs into a factory acc wire. Make sure bass boos it 0. With the BT LL's I run mine on full.
