Need Help Setting Gains
Old Apr 17, 2017 | 08:20 PM
dgoode01's Avatar
dgoode01
Default Need Help Setting Gains
I'm trying to set the gains on my arc moto 600.4 using a multi-meter.
I've watched the videos and read through the post, but I'm not getting results.
The amp is on, power connect light is green, I've turned the 6.5GT head unit up to 75%, I've disconnected the speaker wires from all 4 channels, but when I touch the positive and negative leads to the amp, the MM shows zero. I'm using the test tones from the DD iphone app.
If I connect the speakers back up, I can hear the test tones playing. And If I adjust the gains, I can tell it makes a difference.
What am I doing wrong?
This is my first time trying to do this.
Old Apr 17, 2017 | 08:30 PM
Dsm Limited's Avatar
Dsm Limited
Do you have your digital meter set to A/C current? If so, is it set in the right range value to read the voltage?
Old Apr 17, 2017 | 08:31 PM
uplandpinter's Avatar
uplandpinter
First thing is do not play the test tones through your speakers it will damage them.
Second set you meter to AC not DC.
Old Apr 17, 2017 | 08:35 PM
Roadie13's Avatar
Roadie13
The list of silly crap I've done before: MM set to ACV and lowest scale if multiple scales available? Touching MM leads to amp output not input? MM turned on/tested against a known source? Filters to all pass or flat or whatever it's called on the 600.4? MM leads making solid contact with amp speaker output? If running bridged, connected to correct + and - terminal for bridged setup?
Old Apr 17, 2017 | 08:48 PM
dgoode01's Avatar
dgoode01
Here are some pics. I've got to be missing something.
Attached Thumbnails Need Help Setting Gains-photo854.jpg   Need Help Setting Gains-photo313.jpg   Need Help Setting Gains-photo590.jpg   Need Help Setting Gains-photo801.jpg   Need Help Setting Gains-photo695.jpg
Old Apr 17, 2017 | 09:10 PM
cpbedor's Avatar
cpbedor
What is the volume of your phone set at. I wouldn't recommend using test tones from a iPhone because you're introducing yet another output variable with the phone volume. Can you burn the test tone onto a thumb drive and take it from there? Sounds to me like the one variable (phone) needs to be taken out of the equation
Old Apr 17, 2017 | 09:12 PM
dgoode01's Avatar
dgoode01
Volume on iPhone is at max. Ibelieve one of the stickies had link to down load the tones. I can try that.
Does my setup look correct?
Old Apr 17, 2017 | 09:24 PM
cpbedor's Avatar
cpbedor
Whats the gray wire in your 4th pic, where is it going, why is it plugged in?
Old Apr 17, 2017 | 09:25 PM
dgoode01's Avatar
dgoode01
It is the negative wire to channel 2
Old Apr 17, 2017 | 09:44 PM
cpbedor's Avatar
cpbedor
unscrew your terminal screws and insert your DMM leads into the corresponding hole, screw them down and repeat the process?
Tailwind
Audio Systems
50
Apr 20, 2020 11:55 AM
badazzpred
Audio Systems
32
May 4, 2019 08:24 PM
FrenchieM
Audio Systems
Oct 18, 2017 02:53 PM
ericl
Audio Systems
Sep 7, 2016 03:58 PM
tesnevo
Audio Systems
Aug 11, 2016 12:26 PM
