Arc audio amp/ speaker problems
Old Jun 1, 2017 | 12:18 PM
Dukadd's Avatar
Dukadd
Stage III
Question Arc audio amp/ speaker problems
Hello I have the arc audio 600.4. On my 2012 Harley Davidson street glide. With the stock head unit and I'm running 4 speakers 6.5 . But once I ride the the music stops. When I press the radio power button on and off it plays again for a while then cuts off again. I check for all loose wires and etc still nuttin. Check the power wire it's good. So my question to is have u heard of this problem Befor. I talk to the arc Tec he said it a speaker disconnect and I need the hd power harness but it plug and play and I need a wire diagram to match the wires
Old Jun 1, 2017 | 12:23 PM
Tailwind's Avatar
Tailwind
Originally Posted by Dukadd
Hello. I have a arc 600.4 amp. I'm running 4 5.1/2 they are bridge together. Well my problem is the amp cuts off the green indicator light stays on so I have to cut the radio off and cut it back on ( resetting it) its a speaker disconnect problem I talk to arc tec he said that amp does that . So long story short I had to buy a HD power harness. But it plug and play. And I need to a wire diagram to match the wires or sumtin. I'm lost and the arc tech not responding
U lost me at having 4 5 1/2s bridged together on a ARC 600.4. Please splain that scenario first cause if I was an amp and had 4 5 1/2s bridged to me I would shut off too.
Just trying to help brotha.
T.
Old Jun 1, 2017 | 12:43 PM
Dukadd's Avatar
Dukadd
Stage III
They not bridge wrong description. I updated the original question
Old Jun 1, 2017 | 08:27 PM
HD_Doobie's Avatar
HD_Doobie
Try bypassing the amp to rule out a bad head unit. They are known for issues.
Old Jun 1, 2017 | 08:34 PM
acchd's Avatar
acchd
Ditto the Hardon Kardon head units were know for liquid incrusion issues that caused similiar issues with intermittantly going silent then coming back. Iron Cross Radio www.ironcrossaudio.com will fix your radio for a flat $250 but if it's that good time to consider aftermarket head unit instead.
CapeCoralDyna
Audio Systems
Mar 13, 2019 03:21 PM
bobbyjoes
Audio Systems
Mar 5, 2016 03:25 PM
D RENEGADES
Audio Systems
Feb 28, 2014 12:27 PM
Hammer107
Jul 17, 2009 09:55 PM
gpp
Sep 18, 2008 06:11 PM
