Confused newbie, audio upgrade!
Old Jun 21, 2017 | 10:23 AM
cpbedor's Avatar
cpbedor
The CX62s might fit in the pods. I will check because mine are coming out and I have my pods handy. The magnet is very small. I never checked to see if they'd fit in a batwing pod.
Old Jun 21, 2017 | 10:39 AM
darkwing96's Avatar
darkwing96
Thanks guys for all the replies and good info. I'm not really wanting to be heard in the next county or nothing, just wanting a little more volume at hwy speeds. As far as my budget goes, any where in the 300-600 range. With the CV B52, does that mess with the FM signal on my radio, cause I do still listen to FM stations around my area.
Old Jun 21, 2017 | 11:27 AM
BaggerAudioLab's Avatar
BaggerAudioLab
they drop right in.
Gannicus's Avatar
Gannicus
Normally with the 14 and up bikes you're good to go on the FM reception.
Old Jun 21, 2017 | 11:35 AM
matt76cmich's Avatar
matt76cmich
I had no problem with FM when I was running a Cerwin Vega B2, the B52s little brother, on my 15'. I have since threw away my antenna and listen to music exclusively through thumb drive or Bluetooth.
Old Jun 21, 2017 | 06:42 PM
darkwing96's Avatar
darkwing96
What do guys think about the Polk DB651's or the Kicker CS65? Is the Magic Box the same as Biketronics line leveler?
Old Jun 21, 2017 | 07:16 PM
matt76cmich
The magic box is junk. The BT355 is what you want
Old Jun 22, 2017 | 08:40 PM
torchmaster's Avatar
torchmaster
Originally Posted by Gannicus
All the guys above are correct. The PBR was popular 5 years ago. Not the preferred amp today. As Matt said. On a budget you want the Cerwin Vega B52 or the JL amp for a two speaker set up. Preferably you want 4 ohm speakers. This will give you more flexibility if you ever decide to upgrade.
A few good quality set of 6.5 speakers to buy are:
1. DD AW6.5 speakers with the AT28 tweeters.
2. AD Designs CX62
3. Arc Moto 602
All three of these 6.5's are 4 ohm speakers and will perform well with the amps mentioned.
Which of these speakers would give a warmer sound?
I have been leaning towards the Arc's with the D4
Old Jun 22, 2017 | 08:46 PM
BaggerAudioLab
That combo.
Old Jun 22, 2017 | 09:58 PM
matt76cmich
Originally Posted by BaggerAudioLab
That combo.
Over the AW components? I know I didn't have the AWs long, but the D4 bridged to the AWs seemed better than the Arcs to me. I really liked the 602s while I had them, I could feel the snare drum in my chest at 50mph, I I still felt the AW was better. And yes, my ear could be hearing things slightly different.
