Unsolvable audio problem?
Old Jul 1, 2017 | 11:10 PM
cpbedor's Avatar
cpbedor
My mistake on the amp. I forgot that we were dealing with a BT amp. There's a gremlin somewhere, we just gotta track it down
Old Jul 3, 2017 | 12:29 PM
billyboymr2's Avatar
billyboymr2
There is one thing that everyone seems to be missing here: the right speaker crackled with the LL installed, but not with the converter installed. Regardless of how bad they sound with the converter, the problem is obviously with the LL. Since the problem was intermittent, BT may not have caught it when they tested it. The common thread here is the LL. Once you get the LL back from BT, install it and wait for the problem to occur and swap your RCA cables on the LL. If the right speaker started cracking originally and then left speaker starts crackling when you swapped the RCA's, swap the speaker wires on the amp. If the left speaker keeps crackling, it's the LL. If the right one starts crackling, it's the amp.
Old Jul 3, 2017 | 01:18 PM
arthur's Avatar
arthur
Yep. I see the weak spot as the LL also. I have swapped the RCA cables on the LL and the same speaker is the one that continued to crackle. Again no crackling with the new converter so I dont understand how it could be the ground wire as some have suggested.
I have tried 2 LLs from BT and they both did it. The new converter does not. BT seems to believe it is a signal probelm from the HU but cannot confirm due to the 'closed' nature of the HD software.
Old Jul 9, 2017 | 11:06 AM
arthur's Avatar
arthur
Still waiting on the return of the LL. Just in case that does not work can anyone suggest a good DSP for a road glide? Easy to install? my skills are pretty limited. Probably better if I have a pro do it.
Anyone know a good place in the San Jose ca area for this kind of work? I've done a few searches and seems hit and miss.
Thanks
Old Jul 10, 2017 | 06:56 AM
SgtMic's Avatar
SgtMic
The Arc PSM fits in my '15 rgs.
Old Jul 10, 2017 | 04:43 PM
wils5150's Avatar
wils5150
maybe i missed it but did you try swapping speaker wires? hook left wires to right speaker, right wires to left speaker? see if the problem follows
Old Jul 10, 2017 | 09:05 PM
arthur's Avatar
arthur
After removing the LL I no longer have the intermittent speaker issue. It just sounds distorted from both speakers but is completely consistent. I need to figure a way to flatten the signal from the HU now. Thinking the DSP might be the way to go.
Not sure which ones will work with the BT amp. I've got a message with Mike at BT and hope to hear tomorrow.
Old Jul 22, 2017 | 11:02 PM
arthur's Avatar
arthur
Default Update
Well, the new line leveler came today and I popped it right in. Took it out for about an hour and so far so good. High way speeds near full volume. The first one that had the probelm didn't start till about 2 months in. So Here's hoping this is the end.
On a side note. I did have the dealer do a flash for 0 amps and 4 speakers a couple of weeks ago. I have to say it does not seem quite as clear as it once did but I could be remembering wrong.
Would there be any harm flashing back to 0 amps and 2 speakers? Hate to mess with it if it's working.
Thanks.
Attached Thumbnails Unsolvable audio problem?-img_0865.jpg   Unsolvable audio problem?-img_0862.jpg   Unsolvable audio problem?-img_0863.jpg   Unsolvable audio problem?-img_0861.jpg
Old Jul 22, 2017 | 11:06 PM
Tailwind's Avatar
Tailwind
Thanks.
Leave the flash alone for now. Conduct a HU reset. Instructions should be on the BT inter-web site.
T
Old Jul 22, 2017 | 11:11 PM
arthur's Avatar
arthur
T
Cool. Good idea. Will do that in the morning. Thanks
