like to install a harley audio amp and metra bluetooth interface into HK head unit on my 2010 flhx , but not sure if i could do em inline or would i need a splitter harness? the bluetooth interface exceptes the hd plud, if i can would i install the amp to the HK first then the bluetooth into the amp or vice versa . thanks any input would be helpful
Installed the Metra HD01 on my 2012 UC with stock HK head unit. Works great! It plugs directly into the head unit regardless if there's an amp or not. Unplug the harness from the head unit and this plugs in between. If an amp would be added, it would be a complete separate hookup from this.
Totally seamless and can use my hand controls...can't select between different playlists but you can scroll through the selected playlist. Song title & artist shows up on the screen. It connects just like my vehicles do on startup...also will pause the song when shut off & pick up right where you left off on start up. I send music to it that's stored on my iPhone, as well as stream music to it from Spotify, etc. Well worth it for me.
rblahetka, just got the metra bt-hd01 on the bike ( 2010 flhxse ) and wired.. radio not showing it . went by their directions step by step.my HU didn't have the larger 35 pin connector, it has the smaller 23 pi one. i plug their 35 pin into the Harley HU and splice their two wires ( black & red ) into the 23 pin connector harness red with orange strip and black with green strip. . powered up and nothing ?did you have any issues with the splice in ???? any help would be appreciated , thanks,rickydog ... yes HU is running 8,25 software
