Another newb help me with audio post.
In reading instructions, I see that the sni 35s have gain output pots. The input sensitivity on the sound stream amp is up to 6v. I assume that I want to be as close to the max, without getting distortion as possible. I understand how to set the gains on amp to match rms on speakers, I am assuming I can measure volts at rca jacks on sni 35, at around 3/4 volume, and aim for around 5 volts? Would this be done with a 50hz sample disc also?
I then assume I would set gains on amp using the same 50hz signal, and adjust gains, with speakers disconnected, adjusting to the rms of speakers. After all that is set, hook up speakers and play music, and dial back gains on SNI 35s if there is any distortion?
Is this the correct way or am I over thinking?
Edit: Nevermind. Went back to the beginning of the thread. Wow this thread started Oct 16, 2017!! Anyway what do you have now in regard to speakers and amps? HU? How many speakers? How many amps?
yeah its a long read. Had other work that took priority over sound on the bike last winter.
2002 Electra Glide. Factory radio with cd and cb
Here is what I settled on, keeping the head head unit (will change it out with next winter project), the sni 35 LOC, the Polk MM 652s in fairing, pioneer pro 6900 in lids for bags, and the SS pn4 1000 for amp.
What I am trying to accomplish, is setting the gains on the SNI 35s to be as close to max input as the amp will receive, which is 6v. Then set the gains on the amp, so the amp will not push more than the speakers can maintain.
I was gonna set the polks at 100w each, and the pioneers at 125w each. Ive read here and other places that the pioneers can safely handle 125w and more.
https://www.sonicelectronix.com/item...4aAoLqEALw_wcB
The pots on the SNI are all the way down. The instructions for the SNI say To adjust, set the radios volume to 2/3 full and adjust the SanI-35s pots clockwise to increase the volume level.
i just want to make sure the SNI is putting out less than 6v to amp. If it only puts out 2v, I should be able to increase input sensitivity to make the signal hotter, right?
then make all my final adjustments with gains on amp.
50% on the PAC SNI is generally a good spot to be. If u want to conduct a deep dive u could always get ur hands on an SMD DD1 or other distortion detection device and start at the HU and work ur way thru the SNI and also the amp but the 50% or half way seems to be a pretty well established or accepted practice.
As Gann indicated, u might be thinking a little deep on this but if u want the exposure / education to what is happening behind the curtain electrically then by all means jump into the deep end and please let us know what u find.
T.
You are correct, what i I am ideally looking for is a signal to amp, that is less than the 6v max input for the amp, and a signal that is undistorted.
Sounds like around 50% power on the SNI is where I want to be. Thanks.
Thanks. This is what I was looking for. Maybe I didnt phrase it correctly. Im not looking to go all out crazy testing everything. I was just trying to see how to set the levels on the SNI, I figured a volt test on multi meter would be easy enough.
The default position of the potentiometers on the SNI 35s I recieved are turned all the way down, so they are not pushing any signal. I am just trying to make sure I am not over driving signal to the amp. It sounds like the 1/2 way setting on the SNI will get me to where I need to be.
If I am getting distortion to the amp I can dial it back.
final adjustment are made using the gains on the amp. Easy peasy
