Winter upgrades. Looking for advice.
Old Oct 31, 2017 | 07:51 PM
  #41
sponger's Avatar
sponger
Originally Posted by slyedog
Appreciate that guys. Just really only want to help when and where I can. Gan your always going to be the man. Slye is just another audio guy. LOL!!!!
On the battery topic, I have the Yuasa and really after 3 amps now it works good still but really thinking I may snag a Braille battery and see if it does any better. Other than that as Gann stated hopefully someone will figure out a way to make a 75 amp stator if even possible. Till then the cycle electric is the only upgrade and that's for earlier touring bikes. I am fairly positive my 12 is 50 amp and that started in 09 iirc. So even then the cycle electric isn't an upgrade unless you have a failure.
Like this one?
Attached Thumbnails Winter upgrades. Looking for advice.-screenshot_2017-08-24-19-27-04.png
Old Oct 31, 2017 | 08:48 PM
  #42
slyedog's Avatar
slyedog
Originally Posted by sponger
Like this one?
Yes sir. That is it.
Old Nov 1, 2017 | 07:12 AM
  #43
BaggerBill103's Avatar
BaggerBill103
I went with the Yuasa as well, 500 CCA. What are the specs on the Braille? I know someone with a 2012 that I was told upgraded his stator, but if you guys haven't heard of an upgrade than it must not exist. I'll ask him today, and get back with you.
Old Nov 1, 2017 | 10:49 AM
  #44
Gannicus's Avatar
Gannicus
I was reading about that B3121 in spongers pic and it appears to be a flat out beast!!!
Batteries are normally rated by CCA or cold cranking amps. This dam thing is rated by PCA or Pulse cranking amps and that number is 1380. So, I thought to myself WTF? LOL!! Had not heard of "Pulse" cranking amps before so I looked it up. Turns out it's basically the same as CCA only the term they use is "Hot cranking amps" instead of cold cranking amps. In other words if your bike doesn't start with this dam thing. It ain't the battery!! LOL!! Anyway, I have a YUASA as well. Got it a couple years ago on the way back from Miami per Slye's recommendation. Actually Haze, T and myself all got Yuasa batteries that year. It's been a great starting battery but in all honesty I think my stock Harley battery lasted longer for my sound system. Might invest in the braille as well!
Old Nov 1, 2017 | 06:18 PM
  #45
slyedog's Avatar
slyedog
only option bigger is cycle electric 54 amp. Even cycle electric said not any gain unless there was a issue with the stock stator and needed replacement, otherwise just no benefits for 4 amps.
The Yuasa has the highest reserve but not sure how that is rated compared to the Braille. Braille is 31ah and Yuasa is 32ah but I have a feeling the Braille is much more solid battery. Not sure but always worth a try. Need a damn deep cycle starting battery that fits really.
5280Ruffian
Audio Systems
30
Jun 7, 2018 12:48 AM
Last302
Audio Systems
23
Mar 25, 2016 07:24 PM
Az-Riding
Audio Systems
22
Aug 15, 2014 07:42 AM
Missouri Snowman
Audio Systems
29
Jun 30, 2013 08:59 PM
dowork08
Apr 30, 2008 01:46 AM
