Gettin some clipping from speakers...help
Old Nov 10, 2017 | 07:46 PM
SBates08's Avatar
SBates08
This one is getting hard to pin down.
Old Nov 11, 2017 | 02:55 PM
Gannicus's Avatar
Gannicus
Originally Posted by Babyboy
Sounds to me you may have a loose/poor connection at the head unit.When you crank up the tunes the stereo is demanding more power hince causing it to search the for the usb as the power was shut down and turned back on.
It's most likely the HU bro. The Sony Mex M70BT is a great unit but every now and then you'll find one with quality issues and it takes some time for the issues to show up. I've had to replace a couple units for guys I did installs for doing the same thing you are describing. I'm still running mine with no issues but I've had to return a couple. Check the RCA's to the back of the unit and the rear plug for loose wires coming out of the unit. I've noticed the Blue/White wire going to the accessory power source can be an issue. If it's not getting a good connection to the little black plug the radio will cut in and out as you described. Try running your amp turn on to another source.
Old Nov 11, 2017 | 11:45 PM
KnarleyHarley's Avatar
KnarleyHarley
Thanks Gann....I checked every connection on it, all tight. What I'm gonna try next is just move RCA's to rear output instead of Front...worth a shot...thanks again for guys, very helpful!!
Old Nov 11, 2017 | 11:48 PM
KnarleyHarley
Thanks Gann....I checked every connection on it, all tight. What I'm gonna try next is just move RCA's to rear output instead of Front...worth a shot...thanks again guys, very helpful!!
Old Nov 11, 2017 | 11:53 PM
KnarleyHarley
Hey Gann... I know you recommended another amp awhile back, but what about another HU unit if that's the culprit....Thanks...Don't mind stepping it up a few notches...lol...I do have plans on adding saddlebag speakers....eventually!
Old Nov 12, 2017 | 07:12 AM
Gannicus's Avatar
Gannicus
You want the Pioneer DEH-X8800BHS. This is from Crutchfield so it can be found cheaper but this is a good one if you change out the HU.
https://www.crutchfield.com/p_130X88...c&awug=9016148
Juice
Audio Systems
60
Aug 21, 2019 11:19 AM
tesnevo
Audio Systems
13
Oct 10, 2016 06:11 PM
Cheesehead_13
Audio Systems
Oct 1, 2016 11:56 AM
just plain john
Audio Systems
Jun 15, 2016 12:18 PM
just plain john
Audio Systems
Jul 8, 2013 05:22 AM
