Need install help amp won't power up
Old Dec 2, 2017 | 07:33 PM
Cheesehead_13's Avatar
Cheesehead_13
Default Need install help amp won't power up
2012 SG. Upgrading system
Previous: HK HU, PA RZ4 2000D, Biketronics 7.1.
New system: Aquatics HU, PA RZ4 2000D bridged to DD AW 6.5's with grille mounted DD At28 tweets, DD crossovers.
Situation: I removed my working PA RZ4 2000D. Removed HK HU. Installed Aquatics HU, installed DD speaks, reinstalled amp. Now amp won't power up. Ive checked all fuses (amp and power line at battery) ground, and remote power. All wiring is tight and no fuses are blown.
This is not my strong suit so looking for some assistance. Thanks!
I hope I haven't forgotten anything.
Old Dec 2, 2017 | 08:27 PM
Briguy1's Avatar
Briguy1
Did you check the remote wire fuse and the fuse on the amp?
Old Dec 2, 2017 | 08:48 PM
Cheesehead_13
Thanks, Briguy.I checked the fuse on the amp. Where is the remote power fuse?
Old Dec 2, 2017 | 09:37 PM
SBates08's Avatar
SBates08
Is your remote wire coming from the HU or the cig lighter?
Old Dec 2, 2017 | 10:17 PM
Cheesehead_13
Bates,
Down by the headlight. But, I did pull the cig lighter for the USB charging jack. Did that break a circuit or something? Maybe I should hook up to the remote power from the HU?
Old Dec 2, 2017 | 10:31 PM
SBates08's Avatar
SBates08
Yeah if the Aqautics has a remote wire use it.
Edit: I looked up the wiring diagram on that HU. Most definitely use the blue remote wire.
DoubleD8
Audio Systems
Apr 14, 2019 04:32 PM
Cheesehead_13
Audio Systems
Oct 30, 2018 12:17 AM
decencyxdefied
Audio Systems
Jun 8, 2016 11:54 AM
decencyxdefied
Audio Systems
17
Sep 13, 2015 05:19 AM
Scottie83
Apr 8, 2011 08:26 PM
