Head unit upgrade help
Old Dec 12, 2017 | 10:33 AM
Weeboy1's Avatar
Weeboy1
I don't seek out rain....lol
But ***** happens. Regardless was going to get a cover just prefer the bt as it looks removable and the scosche looked to stay in place and flip up. Unless I'm outta whack.
Old Dec 14, 2017 | 08:00 AM
Gotham's Avatar
Gotham
Would the Sony MEX-M100BT be an upgrade over the
Sony MEX-M71BT?
Old Dec 15, 2017 | 07:33 AM
Gotham's Avatar
Gotham
Couldn't delete post, got my answer earlier reply, my bad.
Old Dec 16, 2017 | 07:57 AM
pingman68's Avatar
pingman68
I have the the soundstream pn2.350d, kappas along with the Aquatic av HU. Great setup, I have no problem hearing at highway speeds. In fact I don’t think I’ve ever had it above 50% on the volume (level 20). Most of the time it’s between 10 and 14 while cruising.
Old Dec 16, 2017 | 09:07 AM
Weeboy1's Avatar
Weeboy1
Pingman,
that's exactly what I'd end up with if I switched to the aquatic.
I'm happy with both the amp and kappas.
Does your aquatic play off a usb stick? I know the color screen version does .not sure about the $300. Aquatic . I don't need Sirius and other options of the upper end unit but do want usb .
Old Dec 16, 2017 | 09:37 AM
pingman68's Avatar
pingman68
Originally Posted by Weeboy1
Pingman,
I have the model with Sirius, so not sure exactly what the difference in capabilities are between the two units. I haven’t tried using an USB stick, I mainly keep my iPod Nano inside the radio, and I also stream Pandora from my phone via Bluetooth.
Old Dec 18, 2017 | 08:53 PM
Weeboy1's Avatar
Weeboy1
Going to go with the Sony.
Wondering , have the SD 350 mounted on top of my hk head unit.
If I replace it with the B52 can I still mount it atop the Sony head unit?
And as far as retro mounting kits and handlebar control interface is metra a better choice than scosche or are the equal?
Thanks for the help.
Ken
Old Dec 18, 2017 | 08:54 PM
Weeboy1's Avatar
Weeboy1
Sorry that's SS 350 PN not SD
Old Dec 19, 2017 | 06:48 PM
yooperhog's Avatar
yooperhog
b52 is tiny. it will fit perfectly up there
Old Dec 19, 2017 | 11:32 PM
Weeboy1's Avatar
Weeboy1
Just need clarification regarding Sony Mex m71bt. Crutch field lists the pre amp voltage as 2 and sonic electronics list it as 5 . Which is it?
