Component Speaker Wiring
Old Jan 15, 2018 | 07:21 PM
soupy371's Avatar
soupy371
Default Component Speaker Wiring
Hey all,
Just confirming that my DD6.5 and BT30s with crossover wired in parallel from the amp and bridged will look like below. It's mainly just the position of the crossover I need to confirm.
Thanks!
Component wiring - bridged
Old Jan 15, 2018 | 08:21 PM
Tailwind's Avatar
Tailwind
U nailed it!!!! Just double check the specs on the BT30 before u pour the coals to the gains. That might be the limiting factor.
T.
Old Jan 15, 2018 | 08:48 PM
soupy371's Avatar
soupy371
Yeah, I guess I didn't pay close attention to that. I got the DD6.5/BT30 as a set used. Is it even wise to run the BT30s bridged to a JLXD400/4??
Old Jan 16, 2018 | 02:26 PM
Kawickrice's Avatar
Kawickrice
I ran the AWs with AT28 tweets wired the same way running the same amp pushing 175 to 180 watts to them and had no problems. I have no experience with the BT30 tweets though
Old Jan 16, 2018 | 03:19 PM
Carlos3621's Avatar
Carlos3621
Hey all,
Thanks!
I just bought the BT30 tweeter's also, but mine did not come with any crossover, could you tell me what exactly are you using for the "crossover"?
thanks,
Carlos
Old Jan 16, 2018 | 04:14 PM
Tailwind's Avatar
Tailwind
thanks,
Carlos
Just get the DD TXO crossovers. Only like $10 each.
The DD BT30 are 150w RMS if I remember correctly.
T
Old Jan 18, 2018 | 02:56 PM
soupy371's Avatar
soupy371
One more question. If I understand correctly after searching the forums, the marked wire on the BT30 goes to the solid or (+) on the crossover?
Thanks again!
wfowill
Audio Systems
Aug 30, 2018 04:25 PM
racenut.pp@gmail.com
Audio Systems
Apr 4, 2017 11:07 PM
BikerDocCO
Audio Systems
Aug 8, 2015 01:51 AM
Scooby1426
Audio Systems
13
Jul 18, 2015 03:14 PM
Tatersalad83
Audio Systems
Apr 19, 2014 09:19 AM
