Keep Blowing FUSES!
Old Feb 20, 2018 | 09:03 AM
cfave's Avatar
cfave
Default Keep Blowing FUSES!
I took my fairing apart this off season and wanted to clean up the wiring underneath. I disconnected everything but when I was removing the positive power it arced off the battery. Didnt think it was a big deal till I started putting everything together. I noticed that my inline fuse was blown. Replaced it and then noticed my fuses in my ARC MOTO amp were blown. I replaced them. NOW every time I go to connect my positive post on the battery I blow the internal fuses.
Any advise?
Inline was an 80 replaced with a 60 and does not blow
replaced both 30 amp in the amp and they both blow
Old Feb 20, 2018 | 12:53 PM
marcodarq's Avatar
marcodarq
have you contacted arc about it?
when you connect your positive cable to the battery is there a fuse in the holder? are you installing the correct rated fuses in the amp,,,,,i ask all this stuff cause i recently watched a lot of ARC install videos and i seem to remember them saying to make the battery connection with no fuse in the holder and once everything was connected to install the fuse. unless this has something to do with an internal cap charging up at connection?
i'd call arc customer service and follow whatever directions they give you,,,,if everything else is hooked up correctly and there are no other shorts in the system, there may be an internal issue in the amp
m
Old Feb 20, 2018 | 01:17 PM
Tailwind's Avatar
Tailwind
In what order r u pulling and installing the battery cables?
T
Old Feb 20, 2018 | 01:25 PM
cfave's Avatar
cfave
Talked to ARC. I just blew air through the system and it seemed to fix it. Arc said that a piece of copper could have lodged itself in there somewhere when pulling the cables in and out that could be causing it. Guess thats what it was. working now.
MDT
Audio Systems
Feb 15, 2017 11:39 AM
SgtMic
Audio Systems
Feb 10, 2017 06:26 PM
2007z71
Feb 7, 2013 09:17 PM
leepetersusn
Audio Systems
May 14, 2012 02:27 PM
02Ultra EG
Aug 15, 2010 06:03 PM
