Not sure how I blew it. I have an in-line fuse and it didn’t blow. I know it’s done because it smells burnt. Has power at the plug and power to remote wire and amp doesn’t do anything at all.
Garrett
have you tried other speakers on the amp to confirm it’s not blown speakers?
Was the amp purchased new? Check all of your wires supplying power/ground and make sure they are not pinched. Make sure your speakers and amp ohm load matches. Adjust the amp gains CORRECTLY and the amp settings. AVC OFF, can’t stress that enough.
Can do. Everything looked great when I pulled the amp but I’ll trace back under the tank. Around the battery all is good and under the fairing is good as well. Changing out the fuse as well to whatever size the soundstream needs.
Time to try this again. Couldn’t find in the little manual what size fuse I should run. I see the amp has 2 40amp fuses in it but what size inline fuse should I run on my power wire?
Also, what’s a good area to start at for gains for the 62.11i? I was thinking 125 watts(15.8 volts) but not sure since they are only 75rms but 200 max.
Garrett
