ground
Old Mar 2, 2018 | 10:31 AM
Dsm Limited's Avatar
Dsm Limited
I guess I don't understand the opposition of running the ground back to the battery or ground lug in front of the battery. If you're pulling the tank to run the positive wire there anyway, what's 1 more wire? It's just as easy to route 2 as it is to route 1 of them. Again, the path of the least resistance.
Old Mar 2, 2018 | 07:59 PM
SSpeeDEMONSS's Avatar
SSpeeDEMONSS
I ran my ground to the bottom fork clamp. What’s the big deal? Plus once the grease wears out there will be less resistance.
Garrett
Old Mar 2, 2018 | 08:10 PM
SBates08's Avatar
SBates08
Garrett
I seriously hope you're full of ****!!!
Old Mar 2, 2018 | 09:54 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Biketronics instructs people to run the ground to the radio mount bolt.
This could lead to ignition whine if any section of the path to the chassis is not at zero ohms.
As other users have stated, you've gotta run a wire to the positive side of the battery, it ain't any more real trouble to run another wire to the negative side. You've gotta remember these amps draw a tremendous amount of current. Any weak links in either the positive wire or the ground wire could cause trouble.
Old Mar 3, 2018 | 08:31 AM
SSpeeDEMONSS
I might have had a couple drinks yesterday and thought that was funny. I have 8 gauge power and ground going to the battery.
Garrett
Old Mar 3, 2018 | 08:40 AM
SBates08's Avatar
SBates08
Garrett
Drinks are GOOD!!!
Respect
Audio Systems
25
Oct 27, 2017 11:51 AM
Hs Fatbob
Apr 3, 2013 08:39 PM
zeroly32
Jun 15, 2012 09:27 AM
72xlhinnh
Ironhead
May 1, 2008 03:58 PM
trusty1
Oct 10, 2007 06:35 PM
