automatic turns on
Old Apr 9, 2018 | 02:34 PM
FOCI's Avatar
FOCI
Default automatic turns on
i have a 2006 flhxi and recently when i start up the bike the radio will turn it self so i shut off the radio any thoughts on why this is happening ?
Old Apr 9, 2018 | 02:36 PM
travelingypsye's Avatar
travelingypsye
What radio? Stock or after market?
Old Apr 9, 2018 | 02:39 PM
FOCI's Avatar
FOCI
stock radio
Old Apr 9, 2018 | 02:48 PM
travelingypsye
I had to re read the original post. Does it turn itself on or off?
Old Apr 9, 2018 | 03:11 PM
travelingypsye
First take the outer fairing off and inspect the fairing brackets. These are known to break and can cause the radio to vibrate messing up the power board in them. If that isn't the case, check all the wiring harness even the wiring to the speakers and see if any are loose or frayed. If all is good there then the radio has internal problems which are common on the harmon kardon units. You just may need to replace it and I would do that with an aftermarket unit.
Old Apr 9, 2018 | 05:52 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
A voltage spike or drop during the ignition cycle can cause this. More prevalent when there is a CD in the drive. The 8.11 software update addressed this issue, slowing down the watchdog circuit and making it harder for a spike or drop to reset the unit. Check the software first. If an update is needed it's a free download from Harley.
Old Apr 9, 2018 | 06:10 PM
travelingypsye
And this guy would know. IC is probably the best in the world at HK head units.
IzzoQuazzo
Audio Systems
May 26, 2017 01:15 PM
davidw221
Audio Systems
Dec 31, 2015 08:59 PM
oakmossy
Jul 2, 2014 07:05 AM
RonH
Oct 27, 2006 10:09 PM
swomack
Oct 9, 2006 09:18 PM
