Amp comparison
Old Apr 26, 2018 | 09:07 AM
JNM3's Avatar
JNM3
Originally Posted by SBates08
Hoyt the amp your looking for is the Evo line SD800.4.
Soundigital 800.4
Also keep in mind that it has no crossovers.
I've got the RF DSR1 ordered to compensate for that.
Old Apr 26, 2018 | 09:09 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Thanks for the info. Looking at the design and specs it doesn't look like something I would want to tinker with. I can't read hippie measurements but it looks a little big.
Old Apr 26, 2018 | 09:22 AM
Stew_FL's Avatar
Stew_FL
They have a marine version.
http://garagebaggerstereo.com/produc...vo-4-pre-order
Old Apr 26, 2018 | 09:36 AM
InthewindMN's Avatar
InthewindMN
Soundigital 800.4
looks like it has a fixed xover at 80hz. Am I reading that right? How useful is that?
Old Apr 26, 2018 | 09:49 AM
haze324's Avatar
haze324
We run these on a lot of builds and are now also sponsored by them --- great amps, but you NEED a DSP or active crossover system to run these amps. No way around it.
Old Apr 26, 2018 | 10:01 AM
JNM3's Avatar
JNM3
Would having the DSP eliminate the need a cross over that come with some component speakers ?
Old Apr 26, 2018 | 10:03 AM
Respect's Avatar
Respect
If you run them both active yes.
Old Apr 26, 2018 | 10:08 AM
Stew_FL's Avatar
Stew_FL
Active: meaning seperate run from the amp then the mid drivers.
Old Apr 26, 2018 | 11:06 AM
Babyboy's Avatar
Babyboy
Originally Posted by badazzpred
Does the SD still retain FM signal like the Arc is the other ?
When I had the SD amps in my sled the FM signal was not degraded and if it was there was I didnt notice it.
Old Apr 26, 2018 | 02:00 PM
sponger's Avatar
sponger
Keep in mind the 800.4 have both 2ohm and 4ohm versions. So figure that out before buying.
bc73
Audio Systems
Apr 27, 2017 06:16 PM
BrysZ
Feb 1, 2015 04:02 AM
davessworks
Sep 5, 2010 08:17 PM
n.o.yat
Feb 19, 2010 11:48 AM
hotpursuit
Jan 15, 2008 12:06 AM
