Arc Audio
Old May 7, 2018 | 10:51 AM
tmcguire17's Avatar
tmcguire17
3rd Gear
Default Arc Audio
PSM. Worth it or just flash the radio? Fosgate Amp, front and rear speaks.
Old May 7, 2018 | 11:22 AM
DAVENRINO's Avatar
DAVENRINO
You may want to ask over here -
https://www.hdforums.com/forum/audio-systems-153/
I don't know how much they are new but there is an A PSM for sale there $275 shipped.
Old May 7, 2018 | 11:50 AM
tmcguire17's Avatar
tmcguire17
3rd Gear
Thanks DAVENRINO. figured there was a better place but need to get my posts up :-) Saw that thread, its sold.
Old May 7, 2018 | 04:56 PM
kojak's Avatar
kojak
Are you running an amp now?
Old May 7, 2018 | 05:11 PM
Dsm Limited's Avatar
Dsm Limited
Your post doesn't say what year or model. I assume you have a Rushmore Ultra. A flash would do it if you can get 1 done. A dsp would do it also at 5-6 times the flash price and a big learning curve. As a 3rd option there is also a Biketronics BT 355 line leveler at about 80 dollars.
Which amp and what speakers are you running?
Old May 7, 2018 | 05:16 PM
tmcguire17's Avatar
tmcguire17
3rd Gear
Its an 18 Ultra. I've got a place that can flash it about an hour away 100$ . And it 2 BT355 if I went that route which I wont. Fosgate has a big hole in its plan with lack of flashers.
Old May 7, 2018 | 10:57 PM
Tailwind's Avatar
Tailwind
What kind of "flash" are you referring to?
That seems to be a very broad term around the audio forum.
T.
Old May 8, 2018 | 06:13 AM
tmcguire17's Avatar
tmcguire17
3rd Gear
T.
yes it can be! Im referring to flashing the radio freq. flat. I already have the front back no amp as its an ultra. Never get a str8 answer as to whether the stock Ultra setup is good to start or if you have to enable the 2 amp 4 speaker settings.
Old May 8, 2018 | 09:12 AM
Tailwind's Avatar
Tailwind
Not sure I would go on the flash hunt unless u are damn sure what flash works best, aka will sit in the shop and work with the person flashing it to ur ears liking.
If you think ur going to advance ur audio stuff in the future the ARC could be a good play for the right price as u grow ur audio system. Right now with 4 full range speakers it will not make a massive difference but u will find value in an actual EQ on a Rushmore.
The solid play here pending a couple variables mentioned above, is the BT355 Loc. They have been proven to work, plug right in and ur not going to be at the mercy of a shop or big cash outflow to ARC.
T
Old May 8, 2018 | 02:29 PM
EGO82's Avatar
EGO82
Arc is a great unit, requires a computer to access. If you want a more user friendly option, do the flash and get the Rockford DSR1 DSP. Bluetooth and controlled by phone or tablet.
