PRV's in Upper Fairing Speaker Pods
Old May 25, 2018 | 01:02 PM
jory434's Avatar
jory434
Default PRV's in Upper Fairing Speaker Pods
Good Afternoon Men-
Just thought I would post about an install I did for a buddy. I asked a while back if a 6.5 PRV would fit in the stock pod, and Haze said they will with a little trimming. He was right as usual.
Used a cutting wheel on a dremel to take away some of the inner structure in the pod, then the sanding wheel on the dremel to clearance a little bit of the "boss" in the lower left section of the picture as you can see it. Speaker dropped right in no problem. Also bent the spade connectors just a little bit to clearance inside the pod. I used some "lathe" screws to attach the speaker to the pod, and it re-installed just as it came out. This was on an '18 model SG, and after the pod was out of the bike, it was actually easier than when I did these same speakers on my personal bike ('13 SG).
Old May 25, 2018 | 01:37 PM
InthewindMN's Avatar
InthewindMN
How did they sound? What was the rest of the system?
Old May 25, 2018 | 04:00 PM
Dsm Limited's Avatar
Dsm Limited
They evidently changed the upper fairing pods on the 17 and 18 batwings. That looks nothing like the 16 and down pod.
Old May 25, 2018 | 04:29 PM
jory434's Avatar
jory434
B3 Horns and an Arc 600.4 amp.
Will add PRV’s in the lower fairings in a couple weeks.
Old May 25, 2018 | 04:30 PM
jory434's Avatar
jory434
I didn’t see any big differences except the color of the plastic being black?
Old May 25, 2018 | 06:12 PM
Nitrochicken's Avatar
Nitrochicken
I’ve heard this bike. For a 2 speaker set-up, the bike rocks.
Old May 28, 2018 | 06:34 AM
duglaura&flhti's Avatar
duglaura&flhti
love to see pixs of the four PRV's installation when completed...Thanks and congrats.
sisson16
Audio Systems
14
Sep 2, 2019 07:06 AM
Clayton24
Audio Systems
Dec 24, 2018 12:35 AM
SSpeeDEMONSS
Audio Systems
Feb 26, 2018 02:04 PM
Geezr Glidr
Audio Systems
Jan 28, 2018 11:26 AM
xdanman
Feb 12, 2014 03:22 PM
