hmmmm, first problem, my hearing sucks... .. but I would describe as missing middles
loudness not a problem, but am going to start with taking up the gain at CV and playing w/ crossover, now set to lo pass
Focals on two channels, amp is still factory
will check for more info tonite when I get home
THANKS
You do not use low pass. That's for subs. Your issue is that amp only puts out 80 watts at 4ohms. You need to bridge the amp and do a reset on your HU if you haven't done so already.
Did the reset, will try the bridgeing in next couple of days... Tnx...
