Adding 2nd amp fuse/wiring question
Old Jul 29, 2018 | 08:06 AM
GLW Mike's Avatar
GLW Mike
Default Adding 2nd amp fuse/wiring question
I'm getting ready to redo/expand..system again..lol.. and had question.
Im adding 2nd amp in fairing. Im gonna need to run another set 8g power wires obviously. Do I run both amps 8g into a double fuse holder and then a single 8g wire to battery from fuse or should the wire from double fuse holder be 4 or 6g to battery. Didnt know if the jumper from fuse to battery should be bigger, then split to 8g.
or skip duel fuse holder and run 2 seperate power lines?
Also, is there a "best" twin fuse holder to use?
I have the Sony radio, JL280/4 and prvs here, just gathering pieces and planning so i can get it all done at once.
thx
Old Jul 29, 2018 | 08:11 AM
travelingypsye's Avatar
travelingypsye
pm sent
Old Jul 29, 2018 | 11:56 AM
sponger's Avatar
sponger
Id run 4 gauge to the front. Single fuse holder by battery, and then a regular 8 gauge splitter in the fairing.
Old Jul 29, 2018 | 01:15 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I'm interested in what y'all come up with. I'm thinking of adding a second amp to the saddlebag, first amp is in the fairing on 8 gauge wires.
Old Jul 29, 2018 | 02:41 PM
haze324's Avatar
haze324
This is pretty standard way of doing it.
Old Jul 29, 2018 | 03:33 PM
shrydog's Avatar
shrydog
Is there anything wrong with having a second fuse holder at the battery and running a second set of 8ga power & ground to the second amp?
Old Jul 29, 2018 | 03:46 PM
ultra_classic's Avatar
ultra_classic
No but a single 4 gauge is neater and same amount of work, and if you pull the second amp out later, you can leave the 4 G in place
Old Jul 29, 2018 | 05:48 PM
Tailwind's Avatar
Tailwind
thx
That micro amp prob only needs 10awg.
T
Old Jul 29, 2018 | 06:08 PM
GLW Mike's Avatar
GLW Mike
Thanks guys.. appreciate the input. It does make sense to run to fairing then split. Thats what I'll do.
Old Jul 29, 2018 | 08:57 PM
GLW Mike's Avatar
GLW Mike
Ok..be patient..this may be remedial but havent found my questions searching forums. I want to do things the right/best way now that im adding 2nd amp in fairing.
Power/ground wire from battery to fairing
1. use 4g for ground as well? (I know 4g for power)
2. In line fuse. What size? I believe 1 amp is rated 35a and other is 40a. What size do I use and what is the preferred /best type of fuse?
In Fairing - Need distribution blocks - 4g to 8g
1. Do I use 2 seperate ones. 1 for power (one 4g to two 8g out) and another for ground? Or is there 1 larger one that has two in (pos/neg) and 4 out 8g to both amps?
2. Again, best one to use?
Thanks again.. I try to research my questions, but sometimes just cant find what I need.
