Adding 2nd amp fuse/wiring question
Old Aug 1, 2018 | 04:32 AM
Hoginedgewood's Avatar
Hoginedgewood
I’m curious what the steady draw is, the math isn’t adding up in my 40 years of playing with electric.
i know #4 copper should carry about 100 amps no problem, I’m guessing it’s not a steady draw, I’m guessing the stator is good for about 40 amps at best, regular probably has ten guage wire at best, but probably 14 guage.
Id be expecting worn out regulator and stator as well as low battery on a regular basis.
but I’m sure there’s plenty of people ready to tell me it works fine.
just not adding up in my head.
Old Aug 1, 2018 | 11:04 AM
Biggzed's Avatar
Biggzed
I found that same one last night and ordered it. I plan on re-wiring everything after I take my annual ride down to the NorCal coast over labor day weekend. I'm going to prep everything to be able to add a second amp and a set of speakers in the bags. I just can't make up my mind on what I want to do.
Zach
Originally Posted by GLW Mike
There are dual ones for power and ground, no fuse in them. I saw this stinger one. Would need to fuse at battery, although im not sure what size fuse if only using 1 fuse at battery for both amps.
https://www.ebay.com/itm/STINGER-4G-...-/360598960172
Old Aug 1, 2018 | 11:54 AM
Juice's Avatar
Juice
I Have 2 of these inline water proof links, 1 going to Fairing and the other going to TourPak.
bobbyjoes
Audio Systems
Mar 15, 2017 08:06 AM
scumBAGGER
Audio Systems
Apr 12, 2015 01:14 PM
Scooby1426
Audio Systems
Apr 6, 2013 10:53 AM
flhxmc
Audio Systems
Dec 12, 2012 03:43 PM
EricFLTRU
May 25, 2011 01:50 PM
