6.5" speaker brackets -2012 Street Glide
Old Aug 7, 2018 | 11:41 PM
matrixx44's Avatar
matrixx44
1st Gear
Default 6.5" speaker brackets -2012 Street Glide
What is every one doing for speaker brackets when installing 6.5" speakers in the fairing using the plastic adapter rings? I'm sure there is a similar post somewhere but I haven't had any luck finding it.
Old Aug 7, 2018 | 11:52 PM
WVJarhead's Avatar
WVJarhead
Hey brother, I did not use any type of bracket to install my 6.5" speakers in my 2012 street glide. The adapters have three screws that attach the adapter to the fairing and then the four screws to hold the speaker to the adapter. No bracket was necessary. That was back in 2014-they are still holding up strong and I have changed speakers a couple times since then.
Old Aug 8, 2018 | 08:16 AM
matrixx44's Avatar
matrixx44
1st Gear
So didnt use these brackets and haven't had any issues?
Old Aug 8, 2018 | 08:28 AM
Juice's Avatar
Juice
Yes, you will need to add those or the upper brackets will fail faster. They should line up to one of the holes on the speaker and/or the adapter that is being used. The upper brackets will still fail, but with out that extra support it will happen a lot sooner.
Old Aug 8, 2018 | 08:42 AM
Solospec's Avatar
Solospec
Alloy art makes an upgraded bracket.
https://www.alloyart.com/bagger/stro...pport-brackets
Phil
matrixx44's Avatar
matrixx44
1st Gear
My brackets are hitting the speaker and wont line up so it sounds like I might have to fabricate a new bracket..
Old Aug 8, 2018 | 08:57 AM
Juice's Avatar
Juice
You should be able to tweak them and get them to fit.
Old Aug 8, 2018 | 09:01 AM
WVJarhead's Avatar
WVJarhead
My mistake, I thought the question was for additional brackets. I did use the orignal metal bracket that was on the bike when I replaced the OEM speakers with adapters and 6.5s. Did not mean to cause any confusion.
Old Aug 8, 2018 | 10:54 AM
matrixx44's Avatar
matrixx44
1st Gear
Phil
Thanks Phil. I did see these but didnt realize the had extra clearance for A/M speakers. Looks like the route to take. Thanks again
matrixx44's Avatar
matrixx44
1st Gear
No worries, just wanted to make sure 😁
G.O.D.
Audio Systems
11
Apr 17, 2017 11:38 AM
Tailwind
Audio Systems
13
Dec 18, 2015 08:54 AM
JMC22
2014-2024 Touring Models
May 13, 2015 11:53 AM
bayboy75
Audio Systems
Aug 18, 2013 08:46 PM
SeaHag
May 6, 2011 05:23 AM
