Upgrade charging system
Old Sep 23, 2018 | 11:29 AM
firemedic4500's Avatar
firemedic4500
Default Upgrade charging system
2014 SGS been running a tm400x4 for years and also heated gear (jacket and maybe gloves when needed). I’m adding a tm400x2 and want to make sure on those colder days my charging system will keep up.
Rockford says the x4 pulls 28amps and x2 pulls 23amps.
Heated gear is 7a for jacket and 2.2a for gloves.
I assume the amps will push their amp rating when pushed to the limit, but I’m not for sure.
Am am I safe or should I start looking at an upgrade?
I also still have the original battery.
Thanks in advance.
Old Sep 23, 2018 | 12:27 PM
Babyboy's Avatar
Babyboy
Stock charging system will have plenty of output at 50 amps to run you heated gear and 2 of the RF 400/4 amps.
I am currently running a JL XD600/6 and a JL HD600/4 and have no issues.
The only thing you may want to consider is upgrading/replacing the OEM battery.
Old Sep 23, 2018 | 02:30 PM
firemedic4500
Thanks for the help, much appreciated
sped
Oct 27, 2018 08:27 PM
LQQK_OUT
Electrical/Lighting/Alarm
Nov 9, 2017 12:59 PM
Boatiac
Dec 19, 2016 01:03 PM
acman308
EVO
Oct 21, 2016 12:25 PM
Terrabella
Jan 3, 2012 11:40 AM
