Prv 8s
Old Sep 24, 2018 | 07:26 PM
SBates08's Avatar
SBates08
Yup that ^^^^^^
Old Sep 24, 2018 | 07:27 PM
USAproud's Avatar
USAproud
Originally Posted by SBates08
Yup that ^^^^^^
Smarter than me ^^^^
Old Sep 24, 2018 | 08:02 PM
azmaniac's Avatar
azmaniac
For what it is...I got plenty of volume!! At a stand still in damn near hurts my ears...just got figure out the tuning on this damn thing...crossover points and eq...just getting frustrated this time last time it seemed a breeze
Old Sep 24, 2018 | 08:08 PM
USAproud's Avatar
USAproud
Sorry I got no experience with those 8s or any for that matter. I cant help on settings
Old Sep 24, 2018 | 09:30 PM
marcodarq's Avatar
marcodarq
try starting out @ 90hz hi pass and tweeking from there, you are not sending it too much power, if anything it's a little low. I'm running the 8MB600FT's and they are working out ok in the 80HZ range, but I'm trying some different power and wiring configs on them. they definately have more output than the first 8MB450's that i tried out. I tried them (the450's) first because I thought i'd get a better lower response, but it didn't work as well as the FT model. if you have band pass capability you might try running them between 80hz and 2-5khz. if you have a dsp in the mix you can get real good control of that.
if i read your post right it said you have them in your lids AND tourpack. is that correct? if so there are some other options, so before i go into that, please confirm the number of speakers and the placement. the other options will let you get more power to the speakers, but will require the small or micro amp addition for your horns.
or you could get the 6MR500-ndy-4's(these are the 4 ohm version, the 6MR500 NDY being the 8 om version) for channels 3&4. the number you put up for that location isn't exactly like the prv sight lists, so i could be off or you could've had a typo on the model number.
m
Old Sep 24, 2018 | 09:51 PM
azmaniac's Avatar
azmaniac
I have 4 horns total in fairing and lids
i have 4 6MR500-NDY 8 ohm
A set in fairing and a set in lowers
I have 4 8mr500ndy 4 ohm
A set in sbd lids and a set in voodoo 8.8 tourpack
For power right now I have 2 jl audio 600/6 amps
Old Sep 25, 2018 | 08:39 PM
marcodarq's Avatar
marcodarq
4 horns channnels 1&2 amp #1
2 6.5's channels 2&3 amp #1, starting hi pass cross at 80hz, tweek.
2 6.5's channels 5&6 amp#1 same
bridge channels 1&2 amp#2, wire mono signal to 8 in tourpack should have 4ohm load with 200watts available( advertised spec)
same for channels 4&5 amp 2 for tour pack other speaker
Channels 5&6 wire straight up,to lids, stereo start crossing the 8's @70 and see how they sound, move up in increments till they rock.
it's just an idea that I would try if i had 2 6 channel amps to work with.
or reverse the power set up to the lids vs the tourpack and see which sounds better.
m
m
Ryanm1
Audio Systems
Jan 19, 2020 06:06 AM
Weeboy1
Audio Systems
Jun 17, 2018 04:55 PM
travelingypsye
Audio Systems
Jan 16, 2018 04:34 AM
big- mike
Audio Systems
18
Jan 15, 2018 06:23 AM
