Lower speaker question again...
Old Dec 27, 2018 | 01:11 PM
marcodarq's Avatar
marcodarq
ok, that will give you a pretty good idea of what the new speaker you choose will sound like and is a good configuration to get your testing done. where were your crossover and gain settings at?
m
as i said before, the rockville sounds just ok. the matts pa 601.4 or the dd vo6.5 are great choices for that location, easy fit and weather treated and dont cost BIG bucks. yes more than the budget brands like Rockville and Sound Q, but......
Old Dec 27, 2018 | 01:27 PM
SBates08's Avatar
SBates08
Originally Posted by Mikes145
I had the kappa on the front channel and the sound qubed on the rear. The tour pack wasn't hooked up.
Did you tune the amp at all or did you just hook em up and try them?
Old Dec 27, 2018 | 01:41 PM
chaz00728's Avatar
chaz00728
Originally Posted by InthewindMN
set the amp on HP and set the xover to about 95hz.
What he said ....Cant run them on full pass !
Old Dec 27, 2018 | 01:51 PM
Babyboy's Avatar
Babyboy
As it was said before the soundqubed need to be crossed around 90 or so depending on how much power your ar throwing at them.
Also those speakers are new and need a little time to break in. The set I have in my fairing are starting to get a good sound to them.
Maybe swap the kappa and the soundqubed from upper to lower fairings with the kappas being a little louder speaker in the lowers it may sound better.
Old Dec 27, 2018 | 02:17 PM
DLennartz's Avatar
DLennartz
Buy four identical quality speakers for your front sound stage. This mix and match bullshit is ridicules.
Old Dec 27, 2018 | 02:41 PM
FrenchieM's Avatar
FrenchieM
Originally Posted by dlennartz
buy four identical quality speakers for your front sound stage. This mix and match bullshit is ridicules.
pm sent!!
Old Dec 27, 2018 | 02:46 PM
USAproud's Avatar
USAproud
What does your system consist of since you apparently know it all?
Old Dec 27, 2018 | 02:50 PM
Babyboy's Avatar
Babyboy
It all depends on what you are looking for in your system.
I have heard some DAM good systems with mismatched speakers. Depends on what frequencies you are wanting to play were and what section of your system to be louder than others.
Alot of mismatched speakers complament each other very well.
Old Dec 27, 2018 | 02:52 PM
SBates08's Avatar
SBates08
That statement is ridiculous.
Old Dec 27, 2018 | 03:00 PM
DLennartz's Avatar
DLennartz
Well since you asked. All Hertz and Fosgate my friend.
Absolutely nothong to improve on. My system sounds like a home theater.
