set the gain in the ball park, turn the switch on the amp to hi pass, slider switch all the way to left, then go to the *** and start in the 12 o'clock position. tweek to the left in small increments, this is lowering the filter level allowing lower frequencies in. do this at full listening volume, turn it left until the sound starts to suffer, the go back to the right untill it clears up, then re-check your gain adjustment, rinse repeat untill it gets to be the best it will be. you might need to have a small charger hooked up, but if yo uget any 'noise' that you can relate to the charger, STOP. turn everything off, charge the battery for a while and start again for a bit. the reason for this is your sound degrades as system voltage drops, and sometimes the noise a charger can put into the system can damage something if you are running on the edge, so better safe than sorry, tweek, then charge, then tweek and do a final check with the bike running.
m
The thing is, I don't really know jack about tuning them. I just watched the sticky video again and do have a Fluke meter. I can set the gain easily enough, but what do you recommend for that setting? 44.7 for 2 ohm and 63.2 for 4 ohm per the chart or is that tuned at 500 watts for each channel since it's a 1000 watt amp? I also am having a hard time setting the crossover on the amp and it's pretty hard to read without more numbers. I have a Kenwood head unit also if that helps. I played with the setting on the head unit for don't quite understand all that either. I'm willing to put the Sound Qubed back in the lowers and try to tune them again.
My suggestion is to put the meter down and tune it by ear. Set your HPF dial between 10:30 and 11 and set the switch to HPF. Remove the RCA's for the other speakers so you're only hearing the ones you're tuning. Do a reset on your HU so all of the settings will be at default. Play your music at 3/4 volume on the HU and adjust gains until you start to hear distortion. Once you're at that point, back the gains down just a smidge. 3/4 volume is now your max volume and you should not go over that...period. Now do the same for the other speakers. I'd run them on HPF as well at 10:00 on the HPF dial. After gains are set, play with the settings on the HU until everything sounds crisp. Make sure to turn the "loudness" off on the HU.
Only when your sitting still without your motor running in your garage. When wind is rushing past your ears at 80 mph and your pipes are screaming at 3000 rpm an addition set of tweeters aimed in the right direction ads tremendously to the volume and SQ of your front sound stage. Ive tried it both ways. There is no comparison.
You have a nice looking system and Im glad it suits your needs, in the end thats all that matters. Out of curiosity, what other speaker combinations have you tried?
Those settings cant be right. I set my Kenwood head unit volume at 28 and set mine to 17.32 volts when I had my Kappas in the fairing (2ohm load for 150 watts) . At 4 ohms you should set it at 24.49 volts. I used ohm's law calculator. Those settings u are using are very high!
All true but, when someone is obviously having trouble grasping things, you don't continue encouraging the use of a meter to set the gains. Set the gains by ear as described above.
I agree 100% with you. The Ohm's law calculator only gives a starting point for a reference in this case 2 then adjust by ear. I was just trying to make a point that his settings we're totally off.
Well since you asked. All Hertz and Fosgate my friend.
Absolutely nothong to improve on. My system sounds like a home theater.
D, Nice job on amp install in your TP...where at in IL. do you live...have you tried a PA (SPL) type speaker like the Hertz SV in your lowers...most everything can be improved...IMO!
Thanks Mike, but do you seriously think the $215.99 Hertz SV 165.1 designed for automobile SPL contests basically just to play loud will equal the SQ of my $600.00 component set? I would feel really bad if they did. So no I never tried replacing my $600 set of Hertz with a $200 set and expecting the sound quality to improve, lol
