Wiring help
Old Dec 8, 2018 | 01:37 PM
Outkast6991's Avatar
Outkast6991
Tabs can go away for sure
Old Dec 8, 2018 | 01:38 PM
rgsboogie's Avatar
rgsboogie
Thanks, I hope that's all it takes to get clearance
Old Dec 8, 2018 | 03:39 PM
marcodarq's Avatar
marcodarq
and yes the rca's labled out, should be a pass through to send signal to another amp or device.
m
Old Dec 8, 2018 | 04:11 PM
rgsboogie's Avatar
rgsboogie
I really appreciate your help I'm almost done with my install the only thing that I'm thinking about is that if I used a out from my amp I won't be able to tune my 6 by 9's on the rear amp, I'm using 4 Outs right now on my DSP probably be better to use one more out to give that signal to the back amp so I can have tunability you agree?
Old Dec 8, 2018 | 05:34 PM
marcodarq's Avatar
marcodarq
yes, use the output from the dsp to the amp so that you can tune.
m
Old Dec 9, 2018 | 12:43 PM
rgsboogie's Avatar
rgsboogie
I appreciate all the help, got everything connected about 2 this morning will tune today and put everything back together, the only thing bugging the **** out of me is the loud thud when I turn my ignition switch off, never had it before with the Diamond audio hxm, what did I do wrong, rookie mistake? Lol
Eric Steward
Audio Systems
Aug 16, 2019 03:21 PM
08FXDL
Audio Systems
Dec 26, 2018 04:27 PM
klimoman
Audio Systems
Nov 28, 2017 01:01 PM
mmats69
Audio Systems
Feb 25, 2017 06:28 PM
Hades02
Audio Systems
Jan 22, 2017 07:26 PM
