18 road glide audio
Old Jan 16, 2019 | 07:51 AM
steverk07's Avatar
steverk07
Smile 18 road glide audio
hi, im looking to upgrade the stereo on my new 2018 road glide standard. just looking for the fairing 2 speaker set up .have considered the "plug and play" rockford and similar products. budget of around 600.00. not afraid of piecing a sysyem together, but really dont want to cut into harness if possible for warranty reason. NOT looking to set off a firestorm of opinions or arguments here , just friendly advise on components that i can consider for this upgrade. ANY advise would be appreciated. , thanks
Old Jan 16, 2019 | 07:54 AM
Juice's Avatar
Juice
What kind of Music do you like?
What kind of riding do you do, Ie. back roads, touring, highway trips?
Juice
Old Jan 16, 2019 | 07:59 AM
steverk07's Avatar
steverk07
listen to mostly classic rock, heavy metal. majority of riding back roads, wear a skid lid helmet, like my music loud but clear.
Old Jan 16, 2019 | 08:09 AM
Juice's Avatar
Juice
You will need a BT355 Line leveler $85.00.
That will leave you just over 500 for amp and speakers.
If staying 2 speakers.
Look at the Cerwin Vega B52 (budget amp) normally around 130-150 on amazon
MMats just came out with a Pro Audio Coax with good numbers 109 each (I have not run these speaker but have run their regular pro audio)
Then you will need a amp install kit 20-30 bucks
Juice
Old Jan 16, 2019 | 08:18 AM
steverk07's Avatar
steverk07
Thanks, also I'm willing to spend more for a quality set up probably around 800.00 max .
Old Jan 16, 2019 | 08:29 AM
Juice's Avatar
Juice
With those speaker I mention again I have not heard that model. But my regular 601.4 had great vocals and decent lower tones for a 6.5. I did have a separate Horn for highs. But this is a nice looking coax.
a little more $ and a JL Amp would make those speakers sound even better.
Juice
Old Jan 16, 2019 | 09:43 AM
Adenton528's Avatar
Adenton528
I just did my dads 18 road glide on the cheap
BT355 - $80
Wiring - $50
Stinger SPX700/4 amp - $250
Got some Crescendo coax for $90 and some kickers for TP for $60
If you're just doing fairing, Id look at a better fairing coax or component setup. There is a thread somewhere for fitment in Rushmore road glide pods. I originally tried using infinity Kappa 62ix and the frame surround was too thick and grille wouldn't pop back on right, so I went to Crescendo.
You may look at the Mmats new coax. I've heard good things about them as well.
All in all, $600 is very achievable for a modest upgrade over stock and will please your ears at most speeds.
Old Jan 16, 2019 | 10:20 AM
Fullbore55's Avatar
Fullbore55
Hertz HCX speakers with BT spacers, using CV or DA amp. Bridge if 4-channel amp.
Which boom do you have?
Old Jan 16, 2019 | 10:59 AM
cshocker's Avatar
cshocker
I would stay away from "plug and play" systems. You will not have to cut into any harnesses to add an amp and speakers. FYI
Old Jan 16, 2019 | 11:39 AM
Chucks1911's Avatar
Chucks1911
The help I will offer comes from experience. DO NOT waste money on a 2 channel amp. Yes, yes, I know. "I only want a fairing set up, blah, blah" LOL. At some point you will be back on here asking about a 4 channel because youre adding lowers, lids, etc. You have been warned lol.
