Noise from DD B3
Old Jan 29, 2019 | 10:11 PM
SS FLHX's Avatar
SS FLHX
Default Noise from DD B3
Hi everyone,
Just curious if anyone out there has any issues with the DD B3's. When I turn on the radio, there is a tick or something like a pop noise from the B3's. Also, when the volume is at 0 with no music playing it makes a humming noise. B3's are running off a SD250.2, amp grounded to battery, and remote is coming off XD600. Thank you.
Old Jan 30, 2019 | 10:54 PM
marcodarq's Avatar
marcodarq
Run your remote wire from the source, not jumped out of the other amp.
m
Old Jan 31, 2019 | 11:21 AM
SS FLHX's Avatar
SS FLHX
I’ll give that a try. Thanks bro
Old Jan 31, 2019 | 12:47 PM
marcodarq's Avatar
marcodarq
also where is the ground point for the 250? try to either ground it at a ground bus bar or somehow on it's own, mine has a very slight hum that i'm pretty sure is from the fan motor and how i have it grounded.
m
Old Jan 31, 2019 | 06:26 PM
SS FLHX's Avatar
SS FLHX
m
I have it grounded to the battery along with another ground for my JL
Old Jan 31, 2019 | 09:12 PM
marcodarq's Avatar
marcodarq
ok, cool. can't really go wrong with that.
m
Old Jan 31, 2019 | 09:36 PM
InthewindMN's Avatar
InthewindMN
Is the 250 power hooked straight to the battery?
Old Feb 1, 2019 | 10:34 AM
SS FLHX's Avatar
SS FLHX
yes both positive with an in-line fuse and ground to negative
Old Feb 1, 2019 | 01:17 PM
marcodarq's Avatar
marcodarq
did you re-wire the remote power yet?
m
Old Feb 1, 2019 | 01:37 PM
SS FLHX's Avatar
SS FLHX
m
I’ll be working on that this evening. Will keep you posted
