Amp/speaker configuration
Old Feb 17, 2019 | 08:31 AM
steverk07's Avatar
steverk07
Default Amp/speaker configuration
Hi,does anyone know what the factory speaker/amp configuration is on a stock 2018 road glide standard ?
thanks.
Old Feb 17, 2019 | 08:43 AM
Dsm Limited's Avatar
Dsm Limited
They utilize 2 - 2ohm crappy speakers in the fairing. The amp is built into the head unit and may be 25watts if I remember correctly.
Old Feb 17, 2019 | 10:19 AM
steverk07's Avatar
steverk07
Let me clarify, is the factory hu set up for 2 speakers / no amp ,trying to see if I need to flash for recommend 4 speakers, no amp.
Old Feb 17, 2019 | 10:39 AM
Dsm Limited
The head unit is flashed for 2 speakers/0amp. Depending on your goals, will determine what you'll need for a flash.
If you are going to run 4 speakers and don't care about front/rear fade control, your flash is fine. You'll want to add a BT355 to your equipment list.
If having the ability to fade is important to you, you'll want the Ultra Flash. 4 speaker/0amp and 2 BT355's, 1 front- 1 rear.
Old Feb 17, 2019 | 10:48 AM
Tailwind's Avatar
Tailwind
And just don't tell the MOCO u are adding aftermarket stuff cause they will not flash it. Most of them won't anyways.
"I want the Ultra Flash cause I'm going to be adding Harley Lowers or a Harley King Tour Pack with speaker pods."
T
Old Feb 17, 2019 | 02:35 PM
steverk07's Avatar
steverk07
Thanks.
painey
Audio Systems
May 23, 2019 02:49 PM
bigreds1963ss
Audio Systems
Oct 29, 2017 02:21 PM
fl1996nos
Audio Systems
22
Jul 15, 2015 09:23 PM
2000 FLHTCUI
Audio Systems
15
Aug 27, 2013 11:20 AM
reserve
Jul 27, 2012 11:13 AM
