Changing Amp&Speakers
Old Apr 17, 2019 | 04:57 PM
Herbherb's Avatar
Herbherb
Default Changing Amp&Speakers
I ride a 2014 Street Glide Special. I plan on leaving the stock head unit in.After reading up on what people recommend.I have decided on the following. Infinity Kappa 62ix 6.5 coaxial speakers and a Cerwin Vega b-52 amp with the bike tronics BT355 line lever and an amp mount.My goals for this is to hear at 80mph. That said how hard is it to replace the amp and speakers? Is there an amp kit that you guys recommend for hooking up the power and ground wires?Ive never dealt with an amp before. Only replaced speakers in truck.Any help/guidance/do not/dos/websites/videos would be great.
Old Apr 17, 2019 | 05:02 PM
Dsm Limited's Avatar
Dsm Limited
A couple quick notes, no amp tray needed. You can use the stock tray. You will also want 2 - Stinger 1.5' RCA cables to connect the BT355 to the amp inputs.
Old Apr 17, 2019 | 05:32 PM
SBates08's Avatar
SBates08
Should only need 1 Stinger for the 2ch amp.
Old Apr 17, 2019 | 05:38 PM
Dsm Limited
Good catch......maybe I shouldn't try quick notes..lol
Old Apr 17, 2019 | 05:52 PM
travelingypsye's Avatar
travelingypsye
To the OP, that is a solid set up but and a big BUT, if there is even a minuscule thought of adding rear lids or lowers then spend app. 30% more and get a good 4 channel amp to begin with. Every regular on this forum has or known someone who had to upgrade as the audio fever tends to sink in when you least expect it like riding with your buds and that someone who has 4/6 or more speakers pulls up. First you think it then you say it....damn that sounds good and I need that.........time to go shopping.
Just saying......
Old Apr 17, 2019 | 05:57 PM
Tailwind's Avatar
Tailwind
Scosche & others have simple motorcycle amp wiring kits. 8 awg is probably suitable for what u r installing.
T
Old Apr 17, 2019 | 06:00 PM
Herbherb's Avatar
Herbherb
would the Cerwin-Vega b54 be a good choice or you got something else in mind?
Old Apr 17, 2019 | 06:08 PM
SBates08's Avatar
SBates08
Most budget builds will usually upgrade at some point in time and tends to move towards the higher tiered speakers, which mainly are 4ohm. For that very reason the B54 is not a solid choice.
Old Apr 17, 2019 | 06:15 PM
travelingypsye
Sadly the b-54 just doesn't have the power needed for a good 4 speaker setup. It will work for the 2 ohm kappas up front but any 4 ohm speaker will require more power. I suggest getting the new nvx vad4 micro amp and use it until you decide you want more. You can always add another one of those to sit in your fairing if/when the time comes. Also with those kappas, that amp just may be enough to run those off channels 1/2 without bridging it.
Old Apr 17, 2019 | 06:55 PM
Herbherb's Avatar
Herbherb
so let me see if i got this right.Using that vadm4 amp I will be able to power the Kappas with no problem.If i were to add lowers later would i need to add a second vadm4?
