Lower Speaker suggestions?
Old May 27, 2019 | 10:01 PM
BigRed7181's Avatar
BigRed7181
Originally Posted by IArider1
I did a set of 8" GZ red baskets in my buddies lowers and they sound amazing and I know a guy whose got 6 or 8 of the 6.5 red baskets on his competition bike. They are great speakers. The mmats are solid performers as well.
I can’t seem to figure out which GZ red baskets? The ground zero web site is a bit hard to navigate. Any chance you could send a link?
Old May 27, 2019 | 10:21 PM
InthewindMN's Avatar
InthewindMN
https://www.ground-zero-audio.com/en...gzcm-6-5n-pro/
Old May 27, 2019 | 10:39 PM
bdrummer0413's Avatar
bdrummer0413
the red baskets will not be a direct fit...in those hogtunes lower adapter...just so you know... red baskets mounting depth are 2.75 inches or close to it
Old May 27, 2019 | 10:40 PM
mrmagloo's Avatar
mrmagloo
Jeez, only 150Hz on the bottom? Even the 8"s are rated for 130Hz?
Old May 28, 2019 | 06:21 AM
BigRed7181's Avatar
BigRed7181
Thanks! I’ll check it out.
Old May 28, 2019 | 07:12 AM
marshallb's Avatar
marshallb
I think it's been reported that they will play a little lower than published spec. If I remember right that 150hz is if you're sending them 300w or better. I know some are sending them that much or more.
Old May 28, 2019 | 01:47 PM
mrmagloo's Avatar
mrmagloo
Thanks bud. Sure would be nice if they gave the spec for a more real world 150-200w max for a bike. The difference between 80 or even 90hz and 130Hz is enormous on these sleds.
Old May 28, 2019 | 03:05 PM
Juice's Avatar
Juice
Had mine crossed at 120hz sounded fine, but I have plenty of low end so I opted to put them back at 150hz. But, I am also sending them 400 watts each.
Juice
Old May 28, 2019 | 03:31 PM
BigRed7181's Avatar
BigRed7181
How do the GZs hold up to the weather? I didn’t t notice mention of weatherproofing.
Old May 28, 2019 | 03:36 PM
Juice's Avatar
Juice
Same as most pro audio. couple coats of camp dry should be fine.
Juice
