Blown speaker need advise
Old Jun 18, 2019 | 03:24 PM
HDK's Avatar
HDK
Default Blown speaker need advise
Looking for recommendations for audio set up. This is what I have currently.
2015 Road Glide
Sony XAV 5000 head unit from Biketronics
Hertz HCX 165s in fairing
MMats PA 601-4 in lower fairings
SS pn41000.d amp
The Hertz speakers were sounding awesome but now sounds like the left Hertz speaker in fairing is blown. Get volume setting above 30 on a song with any bass it sounds like its spitting at you. The Mmats in the lowers just sound awful to me. Very tinny sound is best way to explain it I guess. I've adjusted crossovers on them and can make them sound better but not what I would ever call good.
I'd like to be able to just trade out speakers and get some better sound if possible.
What would be the best 4 speaker change for this amp for front fairings and lowers since I don't want to do lids? Or am I wasting time and money keeping the amp looking for better sound?
Thanks for any advice
Old Jun 18, 2019 | 04:05 PM
InthewindMN's Avatar
InthewindMN
Dumb question, have you tried adjusting the eq?
typically the lowers are for mids and vocals. You won’t get much warm sound there. How does it sound on the road?
Old Jun 18, 2019 | 04:38 PM
HDK's Avatar
HDK
Haven't moved the eq on radio around much other than the 10 presets it comes with. EQ would adjust all 4 speakers and the Hertz sound good. The Mmats do not.
Sound is clear on the road other than the now blown speaker but it's all coming from the fairing speakers. Lowers just don't sound good. I could be looking for something that just isn't possible coming from the lowers. Someone suggested Ground zero's but damn they are high! Especially not knowing what I am getting before purchase.
May have to take it and have it tuned by someone who knows what they are doing but would like to avoid that if possible. Just hoping to find right speaker combo to replace these.
Old Jun 18, 2019 | 05:20 PM
marcodarq's Avatar
marcodarq
get a better quality amp is my opinion, i could never get anything to sound good with the SS amp without a DSP in play. yes the amp is cheap and powerful, but there are much better choices out there that sound way better.
m
Old Jun 18, 2019 | 05:22 PM
packmen21's Avatar
packmen21
+1
ZX2BY2U's Avatar
ZX2BY2U
If I'm not mistaken those MMATs need the highs capped at 4500 or so. Might be your problem
Old Jun 18, 2019 | 06:46 PM
FLHTK2015's Avatar
FLHTK2015
Before we begin, let's figure out if that Hertz is indeed blown?? If so, need to find out why? Are you overdriving them? Maybe need to revisit your gains, x-overs, volume levels, etc. Conservative is a good place to start when warming up new-to-you equipment. Definitely figure out what happened there before moving on to different speaks..
To clarify, are you running the PA601.4cx (coaxial), or the PA601.4, which cap at 5kHz? I have the MMATS PA601.4cx in my fairing. Using BT355 line levelers AND my amp's crossover set around 95Hz, the MMATS made my ears bleed. (Lesson learned about over-filtering a signal) They are a very bright speaker to begin with. I took out the line leveler and fed the amp straight from the factory HU. High-passed them from the amp at 100Hz, now they sound MUCH more full. Let's just say lots closer to what I was expecting from them. It sounds like a different amp with more signal processing capabilities, or a DSP might not be a bad road to tread down, especially when tuning two different animals to sound good together. The MMATS are capable of 120Hz - 20kHz. (I know their box says 100Hz, but the website states differently, would err on the side of higher than lower) Also, with a DSP you can cap the highs on them like ZX2BY2U suggested. Overall, I don't think they're a BAD speaker, but I'm not floored by them at the moment. I had the same perception of them as you, until I fed them a fatter signal. Again, be sure your gains aren't set too high. That will make any speaker sound like sh*t. Just my
BTW, Just bought an Arc PSM the other day. Waiting for it's arrival. Will update as to the MMATS sound quality after some fine tuning EQ action
Old Jun 18, 2019 | 07:04 PM
HDK's Avatar
HDK
Originally Posted by FLHTK2015
To clarify, are you running the PA601.4cx (coaxial), or the PA601.4, which cap at 5kHz? I have the MMATS PA601.4cx in my fairing. Using BT355 line levelers AND my amp's crossover set around 95Hz, the MMATS made my ears bleed. (Lesson learned about over-filtering a signal) They are a very bright speaker to begin with. I took out the line leveler and fed the amp straight from the factory HU. High-passed them from the amp at 100Hz, now they sound MUCH more full. Let's just say lots closer to what I was expecting from them. It sounds like a different amp with more signal processing capabilities, or a DSP might not be a bad road to tread down, especially when tuning two different animals to sound good together. The MMATS are capable of 120Hz - 20kHz. (I know their box says 100Hz, but the website states differently, would err on the side of higher than lower) Also, with a DSP you can cap the highs on them like ZX2BY2U suggested. Overall, I don't think they're a BAD speaker, but I'm not floored by them at the moment. I had the same perception of them as you, until I fed them a fatter signal. Also, be sure your gains aren't set too high. That will make any speaker sound like sh*t. Just my
They aren't the cx. Just the 601.4. Would you recommend amp swap or dsp?
Old Jun 18, 2019 | 07:16 PM
FLHTK2015's Avatar
FLHTK2015
Best to figure out what happened with the blown speaker before making any moves
Old Jun 18, 2019 | 07:44 PM
HDK's Avatar
HDK
I'm not exactly sure it is blown. It sounds very good at volume levels below 35 on the head unit. If you get higher than that on a song with any base in it sounds like a vibration coming from it or like it's spitting at you. May have had the gain too high on it but other one is fine and still sounds good. The speakers are about 5 years old and have alot of use on them so may just be worn out as well. Not really sure. I took it off today and could not see any thing wrong with it.
