Will it Fit?
Old Jul 6, 2019 | 12:38 PM
Tailwind's Avatar
Tailwind
Stinger on tray
NVX in clutch cubby
B52 on clutch side of BT Bracket
DSR horizontally behind the headlight. (If the DSR wont fit there either sell it and get the ARC PSM and mount on brake side BT Bracket.
I have seen a DSR angled beneath the brake side fairing speaker but it was a pretty sloppy instal practice.
I'm betting a couple cases of adult soda that the DSR will not fit on the brake side bracket without some significant hacking.
T
Old Jul 6, 2019 | 01:33 PM
GunslingersNation1's Avatar
GunslingersNation1
Originally Posted by Tailwind
Stinger on tray
NVX in clutch cubby
T
Out of curiosity, why not do everything you just mentioned, but mount the DSR on the brake side bracket? I have seen pics of the bracket mounted amps, Im a little worried that the B52 wont fit, and allow the fairing back on. Worst case, I could buy a second NVX, since we already know it works in the cubby, and sell the B52. I acutally like the NVX better than the B52 because of the speaker wire connections. Thoughts?
Old Jul 6, 2019 | 02:03 PM
Tailwind's Avatar
Tailwind
Because of that additional piece on the brake side bracket it pushes everything u mount there exponentially closer to the tapered part of that fairing. Two inches closer to the tip of the fairing before mounting anything there is just not good as the fairing taper is pretty steep in that area.
T
Old Jul 6, 2019 | 02:32 PM
GunslingersNation1
I just ordered a second NVX. I'll mount them together in the cubby, which has the added bonus of letting me mount the distribution blocks on the brake side, keeping it away from the RCAs on the clutch side.
Old Jul 6, 2019 | 02:42 PM
Tailwind's Avatar
Tailwind
Why not a SD 600.1 & pound 300 watts each to the bag lid 8s?
T
Old Jul 6, 2019 | 02:45 PM
GunslingersNation1
T
Because it's for the running the 4 mids in parallel, lowers on one channel, fairings on the other. The second NVX is for the horns. The Stinger is bridged to push 350 to each of the 8s.
Old Jul 6, 2019 | 03:05 PM
Tailwind's Avatar
Tailwind
4 6.5s off Stinger in stereo 125 w each.
Bag lids off SD600.1 2ohm 300 w each @ 12V wired in parallel.
2 sets of Horns off NVX VADM2 wired in parallel.
Stinger on tray
NVX in cubby
SD 600.1 on clutch side
DSR behind the headlight.
Go riding!!!!!
T
Old Jul 6, 2019 | 04:30 PM
Dsm Limited's Avatar
Dsm Limited
Originally Posted by Outkast6991
This is what he meant when he said behind the headlight
That's exactly what I meant!!
Old Jul 7, 2019 | 10:16 AM
GunslingersNation1
How is that piece attached? The JM tray doesn't have a lip like that, does it?
D_Cantelow
Audio Systems
13
Jul 21, 2019 04:34 PM
The Q
Touring Parts
Mar 11, 2014 05:06 PM
slammd
Audio Systems
Feb 10, 2014 07:05 PM
pauly3
Touring Parts
Mar 20, 2013 06:49 PM
wareagle_84
Mar 26, 2010 09:39 AM
