Tour pack speaker guidance
Adding biketronics system, but having a hard time finding any info on speakers performing well in the pods.
Thanks.
I have experience with BT, so not afraid to use their product again.
If I want, I can move the fader to the rear on the radio (I'm running a Sony XAV-AX5000 in a BT mounting setup) a few spots and it really makes the tour pak speakers much more noticeable- and they're downright loud if I lean backward! My total system is the XAV-AX5000, Biketronics BT4180, Arc Moto 602s in the fairing and the Alpines in the pods. I ran the Alpines in both my '15 Ultra Limited Tour Pak pods (1st pic) and now they're in my '17 Road Glide Ultra pods (2nd pic).
Mmats = 360.00
Stinger 240.00
BT LL= 90.00
Vtwin adapter =100.00
Amp install 40.00
I would seriously consider a different amp though. While Biketronics makes a quality product with outstanding customer service, I would opt for something with ***** to adjust gain and high pass filtering.
Like Fireball Jack, I'm also running the Mmats 601.cx and stinger as part of my system. They are capable of getting the job done and allowing you to achieve your goals. The Mmats require very little fine tuning which is especially important if you are using your factory HU which lacks an EQ. The Stinger will also give you x-over and gain adjustments that are lacking on the Biketronics amps. That alone will be a benefit for fine tuning your system now, and going forward if you end up making any changes or upgrades down the road.
Lots of other choices out there, just plan ahead with gear that has some flexibility. The Biketronics amps lack that flexibility.
To help pitbull on his quest.....
I'm also curious as to what others are finding for tour pack pod speakers capable of enough volume to keep up with the rest of their system at freeway speeds.
Obviously it depends on what's in the fairing, but what are some of the options capable of above average volume, that will fit in the rear pods, with or without an adapter.
The 4 Mmats speaker system works well, but in order to balance them out, you still end up turning down the front speakers a little and leaving a bit of fairing volume on the table in order to hear the rear speakers. I've overcome the balance issue with a little bigger amp on the tour pack pods in the past.
What's everyone's go to choice for the tour pack?
We know the Mmats 601.cx sounds good, has plenty of volume, and fits with the vtwin speaker adapters.
I believe the Polk 652 mm fits with no adapter, but have never tried them, so hopefully someone else can chime in on their sound quality and volume capabilities.
