Looking for a little advice.
Old Feb 4, 2020 | 11:38 AM
  #51
mikes300's Avatar
mikes300
Originally Posted by marshallb
Didn't you try to use it as an Lpad though? That's not what it's for, it's for the low level signal not speaker level.
Stick it in the cubby and adjust on the fly easy peasy.
Yes I tried both, (it didn't work inline to the new amp either, i tried just for the heck of it) ended up just adding another amp (should have just gone that way in the beginning) and the cubby is for other stuff lol, I'm not fumbling around in there when for a few bucks more I can have a clean and functional (via the hand controls) installation.
Old Feb 4, 2020 | 11:40 AM
  #52
mikes300's Avatar
mikes300
Originally Posted by Twistedsherrie
I guess I would rather use a button and feature that is already there for the fade.The reason I looked at the stinger wire kit was it appears to have every wire and plug I may need or is there a lot in the kit that wont be used ? One more question.... is the difference between the front and back BT355 just the plug ?
yes just the plug, not sure on the kit I didn't look at it. I'll have 2 BT LL's available shortly, one front and one rear.
Old Feb 4, 2020 | 11:45 AM
  #53
marshallb's Avatar
marshallb
If you tried it after you used it for the wrong purpose I'm sure it didn't work anymore. I'm not saying they are fool proof, but I'm sure that they are capable devices.
Old Feb 4, 2020 | 11:57 AM
  #54
mikes300's Avatar
mikes300
Ah, yes that is a real possibility, I only tried it as others said it would work.
05sportie
Audio Systems
Dec 10, 2019 03:23 PM
Rengnath
Audio Systems
11
Oct 3, 2018 05:07 AM
BrysZ
Audio Systems
39
Oct 1, 2016 02:01 PM
HD REBEL
Audio Systems
14
Apr 5, 2015 01:31 PM
drrandall1
May 22, 2008 10:34 PM
