Boombox power
Old Jan 11, 2020 | 03:00 PM
Redfish911's Avatar
Redfish911
Default Boombox power
I have a 2018 RGS and for the last few days when I start the bike the radio doesn't always come on. I can turn it off and back on and sometimes it powers and sometime it doesn't. Has anyone else experienced this?
Old Jan 13, 2020 | 06:46 AM
Redfish911's Avatar
Redfish911
I found out it doesn't turn on when it's hot. I have a CV-B52 amp under the radio on a BT shelf. Does the Boombox have thermal protection?
Old Jan 13, 2020 | 09:28 AM
teedoff65's Avatar
teedoff65
Is you're bike cold when you start it? You mean it gets hot from just the ambient temps? That doesn't sound normal. Some amps have a shutoff mechanism when it gets too hot. Not sure about HU, thought I would bet they do. Still, they have to get pretty hot before they would shut down.
You could try moving your amp. I think that amp is small enough to sit behind the HU on top of the headlight.
Old Jan 13, 2020 | 10:52 AM
Redfish911's Avatar
Redfish911
I thought about that but it's been running like that for 6 months with no issues. But so far it only fails to power up after a warm start.
Old Jan 13, 2020 | 11:01 AM
SBates08's Avatar
SBates08
My next move would be to pull the fuse on the amp and go ride. If it still does it, the heat from the amp isn't the culprit.
Old Jan 14, 2020 | 05:57 AM
Dsm Limited's Avatar
Dsm Limited
The only time my Boom unit hasn't booted up is when battery power was relatively low. If the bike slow cranks, it won't boot up the radio. Last season my battery was getting weak, not bad yet, but weaker than normal. Installed a new battery, and hasn't done it since.
Not saying that is your issue, just thought I'd throw that out there.
Old Jan 14, 2020 | 12:07 PM
Redfish911's Avatar
Redfish911
I did inspect the main fuse and noticed some corrosion. I cleaned it up and put some dielectric on it. I'll check the other fuses later. This business of working is overrated.
just plain john
Audio Systems
May 27, 2018 10:20 AM
CrackOfDawn
Audio Systems
Jun 23, 2017 02:44 PM
Gone Riding
Audio Systems
56
Nov 15, 2013 07:54 AM
Arizona Mike
Sep 18, 2012 09:31 PM
Astro
Sep 2, 2011 09:20 AM
